oil change time ???
   / oil change time ??? #1
nhtrekker
Center Harbor , NH
(03) Massey gc2310
Does anybody use diesel synthetic oil in your tractor. I have a massey gc2310 2005 and would like some advice. I was looking at Shell rotella THANKS, Don
   / oil change time ??? #2
We have run T6 5w40, and am running T5 10W30 semi synthetic currently. Wont hurt at all.
Welcome aboard.
   / oil change time ??? #3
Absolutely, lots of us do. Make sure you aren't buying the blend synthetic and paying for true synthetic. Will run better in cold weather.
   / oil change time ??? #4
I use Amsoil synthetic in all my equipment - tractor, trucks, cars, lawn mowers, compressor pumps, any machine that takes oil.
   / oil change time ??? #5
I went to Shell T6 after the 50 hour break in period. I use it in all my diesel engines. Check your operations manual for restrictive use if any on synthetic use. Some manufacturers dont want you to use synthetic till after a break in period.
   / oil change time ??? #6
I ran Amsoil HDD 5W30 in my GC2300 (now sold) and likes it's performance a lot (especially in winter).
DEWFPO
   / oil change time ??? #7
Dont get me wrong here, I uses Rotella in some things, but its the cheapest diesel rated oil you can buy. Its kind of the Fram Oil Filter of oil. I also use lots of Fram Oil Filters for that matter.
In my research I found out lots about oil. For the same money Mobil 1 makes a full synthetic Diesel rated oil that is twice as good. I get it at WalMart and Meijer.
Chris
   / oil change time ??? #8
I use the Lucas diesel oils. Seem to work well.
   / oil change time ??? #9
Chris
Is the M1 5w40?
   / oil change time ??? #10
Is there any problem with using 5w-40 weight synthetic oil if the manual calls for 15w-40, or 10w-30. Is the 5W side of the oil too thin?
UNUSED LANDHONOR MAP-16-24W MINI MOUNT PLATE (A54757)
UNUSED LANDHONOR...
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51691)
2012 Trail-Eze...
UNUSED DIGGIT HEAVY DUTY 20'X20' ALL-STEEL CARPORT (A54757)
UNUSED DIGGIT...
2018 Skyjack SJIII4740 40ft Scissor Lift (A52377)
2018 Skyjack...
2007 Ingersoll Rand P185WJD Towable Diesel Air Compressor (A52377)
2007 Ingersoll...
2016 FREIGHTLINER  CASCADIA (INOPERABLE) (A53843)
2016 FREIGHTLINER...
