oil change time ???
   / oil change time ??? #1
nhtrekker
Center Harbor , NH
(03) Massey gc2310
Does anybody use diesel synthetic oil in your tractor. I have a massey gc2310 2005 and would like some advice. I was looking at Shell rotella THANKS, Don
   / oil change time ??? #2
We have run T6 5w40, and am running T5 10W30 semi synthetic currently. Wont hurt at all.
Welcome aboard.
   / oil change time ??? #3
Absolutely, lots of us do. Make sure you aren't buying the blend synthetic and paying for true synthetic. Will run better in cold weather.
   / oil change time ??? #4
I use Amsoil synthetic in all my equipment - tractor, trucks, cars, lawn mowers, compressor pumps, any machine that takes oil.
   / oil change time ??? #5
I went to Shell T6 after the 50 hour break in period. I use it in all my diesel engines. Check your operations manual for restrictive use if any on synthetic use. Some manufacturers dont want you to use synthetic till after a break in period.
   / oil change time ??? #6
I ran Amsoil HDD 5W30 in my GC2300 (now sold) and likes it's performance a lot (especially in winter).
DEWFPO
   / oil change time ??? #7
Dont get me wrong here, I uses Rotella in some things, but its the cheapest diesel rated oil you can buy. Its kind of the Fram Oil Filter of oil. I also use lots of Fram Oil Filters for that matter.
In my research I found out lots about oil. For the same money Mobil 1 makes a full synthetic Diesel rated oil that is twice as good. I get it at WalMart and Meijer.
Chris
   / oil change time ??? #8
I use the Lucas diesel oils. Seem to work well.
   / oil change time ??? #9
Chris
Is the M1 5w40?
   / oil change time ??? #10
Is there any problem with using 5w-40 weight synthetic oil if the manual calls for 15w-40, or 10w-30. Is the 5W side of the oil too thin?
2016 FREIGHTLINER  CASCADIA (INOPERABLE) (A53843)
2016 FREIGHTLINER...
2016 Kubota SVL 75-2 (A47477)
2016 Kubota SVL...
2006 JLG 2030ES 20ft Electric Scissor Lift (A54811)
2006 JLG 2030ES...
Echo SRM2620 Gas Trimmer (A52377)
Echo SRM2620 Gas...
2016 Hitachi XZ300LC-6 (A47477)
2016 Hitachi...
