Alright. I screwd it up good now.
   / Alright. I screwd it up good now. #1
pickeringchris
Gold Member
Ill make it short. No pun intended.
Putting 2 led flood lights on my ck27. All wired up. Turned them on for the first time. Nothing. The + wire was rather hot. I figured must be a bad ground. Go to turn the key on and now the cluster is dead. Tractor won't turn over. Checked fuses, can't see a bad one. Battery has a full charge. :-(. Any words of advise appreciated.
C
   / Alright. I screwd it up good now. #2
You have a dead short in there some where. disconnect every thing you hooked up.
   / Alright. I screwd it up good now. #3
C
Chris, did you check the main fuse the 60 amp in line.. Usually near the alternator. Of course first unhook what you wired up and check this fuse..
Just found 60amp in my wiring manual. Gotta go out and find it/check it. No juice to anything so that's gotta be popped. I'm pretty good with basic wiring. Moreso Ac than dc. Don't know what I could have screwed up.
   / Alright. I screwd it up good now. #5
to blow the 60 amp, something touching ground, would be my first thought good luck.. wish I had a schematic to help you.
Yep. Here's the main fuse.
Ok. This is what I did.
Stripped out 100% of wiring I put in for lights.
Installed new main fuse.
Everything is back to normal and functioning.
I hooked up the lights to the rear bullet connectors installed @ the factory.
Turned key on and nothing.
Checked fuses and a 7.5 amp is blown. "Combination switch".
I am frustrated to all HeII. :-(
   / Alright. I screwd it up good now. #10
It is going to be OK, we can fix this......now, do you own an Ohm meter. (volt ohm milliamp multimeter).. if not go buy one.. and call back.
2016 Kawasaki Mule KAF620S 4x4 Utility Cart (A55973)
2016 Kawasaki Mule...
Portable Restroom (A54865)
Portable Restroom...
2016 Cat TL1055D Telehandler (A56435)
2016 Cat TL1055D...
2018 Deere 323E (A53317)
2018 Deere 323E...
UNUSED FUTURE 32" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 32"...
1996 Parker Trailers TravAlong T/A Gooseneck Livestock Trailer (A55787)
1996 Parker...
