New Fence Finally Going Up.
   / New Fence Finally Going Up. #21
High tensile wire is too light for brace wire. Use #9.
   / New Fence Finally Going Up. #23
That is just plain bad information. That's all I've ever used, double wrapped on a long pull, single wrapped on a short pull.
Of all the things I've had to replace when fixing fence I have built, my brace wires were never one of them.
And BTW we tighten woven wire with a tractor.
   / New Fence Finally Going Up. #24
Nice fence. Looking forward to watching your progress as you post more pics.
What brand of fence wire are you using, Agriman? The label looks like it says Stay-Tuf?
All in all do you think a driver much better/easier than a post hole digger?
Yes Sir! No doubt about it, even an old driver is better than an post hole digger. Especially the manual kind.
   / New Fence Finally Going Up. #26
I have always used #9 for brace wire. I do not know the gauge of high tensile. I have always strung woven wire.
Hi tensile wire is 12.5 gauge and 200k psi rated.
#9 brace wire is 9 gauge and 40k psi rated.
   / New Fence Finally Going Up. #28
That doesn't sound right.
Give me a minute to switch to my lap top and I'll provide a link.
***EDIT***
210,000 PSI, 12.5 gauge high-tensile wire
I'm still looking for the #9 tensile strength.
***EDIT PART2***
I cant seem to find a rating on just the brace wire. The only thing I can find is a woven wire with #9 top and bottom wires. Those are rated at 70K PSI.
   / New Fence Finally Going Up. #29
What driver do you use?
   / New Fence Finally Going Up. #30
***EDIT***
***EDIT PART2***
You have 12.5 gauge wire rated higher than 9 gauge wire. #9 is heavier than 12.5 gauge.
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
40 ft. Shipping Container (A55973)
40 ft. Shipping...
2014 Toro Z-Master 3000 Series 52in Zero Turn Commercial Mower (A56857)
2014 Toro Z-Master...
2021 Ford F-150 Ext Cab 4X4 Pickup Truck (A55852)
2021 Ford F-150...
Toyota 7FGU35 8,000lb. Propane Forklift (A55973)
Toyota 7FGU35...
2014 Volkswagen Jetta Sedan (A56859)
2014 Volkswagen...
