ROPS Tubing: Drilling Holes
   / ROPS Tubing: Drilling Holes #1
npalen
Elite Member
Beloit, KS
Kubota B9200 HSTD and Mahindra 3015
I've noticed in quite a number of discussions on the TBN forum that it is a unanimous no-no to drill holes in ROPS tubing but rather accessories such as lights should be attached with other means such as u-bolts. I understand the logic of safety and liability but would just like a little more information. Is the ROPS tubing high carbon material where a drilled hole might weaken the structure or lead to stress cracks?
   / ROPS Tubing: Drilling Holes #2
I drilled holes for my lights have not seen any adverse effects to the rops. Bit then again I havnt rolled my tractor
   / ROPS Tubing: Drilling Holes #3
No the ROPS tubing aren't high carbon material.
   / ROPS Tubing: Drilling Holes #4
My T293 has some holes already drilled which appear to be for accessories. I enlarged one on each side from 3/8" to tap for a 1/2" bolt. It worked for me just fine and plenty of meat left to be supportive. As Combustix said, I have not rolled mine either.
   / ROPS Tubing: Drilling Holes #5
The rational behind not drilling holes is if you do roll your tractor and the ROPS fails the mfg can say that it's your fault because you weakened the structure.
   / ROPS Tubing: Drilling Holes #6
I agree that in general it's not a good idea to drill holes in the ROPS, and I avoid drilling into the ROPS if at all possible; but I've drilled a couple of holes for 1/4-20 bolts, and the amount of material removed is next to nothing. If you're going to drill into your ROPS, use common sense and keep the holes to a minimum in number and size.
The lawyers are the prime reason for the "no drilling the ROPS" warnings from the manufacturers.
   / ROPS Tubing: Drilling Holes #7
I confess, I am on ROPS driller also.
   / ROPS Tubing: Drilling Holes #8
Exactly!
   / ROPS Tubing: Drilling Holes #9
There could be also be issues if you go to trade tractors . I doubt if anyone would even notice , but you never know . I put a 590 Case backhoe on it's side at work . Got it back on it's wheels and nothing broke . Had the dealer check it out , just to be sure . Doors ,windows , fenders , roof , nothing damaged . However , they said if and when machine got traded the ROPS would be considered compromised . They had to cover them selves . On a side note , it's amazing how much dirt is under that rubber floor mat .
   / ROPS Tubing: Drilling Holes #10
Good lord people get a grip, they will be printing instructions on toilet parer for some of you next!
Payment Terms (MUST READ) (A50774)
Payment Terms...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
90018 (A48082)
90018 (A48082)
2013 Isuzu NPR-HD 16FT Reefer Box Truck (A50323)
2013 Isuzu NPR-HD...
JOHN DEERE 3040 TRACTOR (A50459)
JOHN DEERE 3040...
2004 TAKEUCHI TB175 EXCAVATOR (A51242)
2004 TAKEUCHI...
