Your laugh for today
   / Your laugh for today #11
We are showing our age here with this. You can't fault the reporter if he or she just repeated what the DOT told them they were doing verbatum. You have a lot of young people at work today that have never seen an old fashioned blow torch and don't realise there are two types of torches. When they hit the oxygen lever on the cutting torch it blows out the molten steel from the cut hence the name. Most guys running a cutting torch have little understanding of the chemistry going on down in the cut.
Some of these "Young folks" have been on the job for fifteen years or better and are now the foreman or super and if he calls it a blow torch all his crew will call it a blow torch.
I still have a hard time keeping a straight face when dealing with a young super with rings in his ears and tattooed biceps. It's just hard to take them seriously, especially if the problem we are discussing is a small one that would not be a problem if the super had read the plans correctly or the spec book.
   / Your laugh for today #12
We _( Grandad) had 2 or 3 of them. Only real job I remember using them for was sealing up cast iron pipe.
I thought it was great fun to light them. Hope to find at least 1 in treasure hunt. (Trash & Treasure thread)
Had lots of fun as a kid, also great fun to crank the old forge. When Grandad wasn't looking I'd really wind that thing up.
AH the good old days.
Jim
   / Your laugh for today #13
My dad had two blowtorches that he used to heat the glow plug on a single cylinder diesel engine. The engine drove a water pump thru a long flat belt. The engine was high up on the river bank and the pump was down next to the normal water level. The blowtorch would heat the glow plug to cherry red, then he would start to spin the flywheel by standing on a spoke. He had two blowtorches because sometimes it took more than one fuel fill of the torch to get the plug hot enough. Once the engine was running it would blow smoke rings out the exhaust.
That was back in the 1940's before we got electricity. I now have one of the blowtorches on the shelf in my office. My son has the other one.
   / Your laugh for today #14
Have never used mine for anything except a display object, if I need a portable heat source I use a propane torch. I sent the writer of that story in the paper an email with the same attachment shown here about his goof telling him "THIS is what a blowtorch is...." :laughing:
our local paper covered a police story one time and mentioned the officer had to change the clip in his revolver 2 times.. etc.
I wrote the editor on that one though it did not get printed.. ;)
blowtorch.
hmm.. something about pouing gasoline into a container.. pumping it up and lighting it that makes me feel a tad unsafe.. ;)
   / Your laugh for today #16
blowtorch.
it was not the gas in the pumped up container you had to worry about. Under the nozzle was a small cup that you filled with gas to heat it up so that the torch would light and stay lit.
   / Your laugh for today #17
blowtorch.
   / Your laugh for today #18
   / Your laugh for today #19
We use to call cutting torch the flaming scissors years back.
   / Your laugh for today #20
We use to call them fire axes. I've asked a lot of guys over the years after seeing their cuts with an oxygen acetylene torch, what brand of chain saw did they use to make that cut. :laughing:
2025 CFG Industrial QK16R (A50123)
2025 CFG...
Deere 333E (A50123)
Deere 333E (A50123)
2022 K-Z Sportsmen 260BHSE 28ft T/A Travel Trailer (A51694)
2022 K-Z Sportsmen...
Hay Van FL-95 Bale Squeezer - Hydraulic Bale Grab for Round and Square Hay Bales (A53473)
Hay Van FL-95 Bale...
2012 FORD F450 SERVICE TRUCK (A53426)
2012 FORD F450...
2019 Ford Transit Cargo Van (A51694)
2019 Ford Transit...
