2013 looks to be a good year for Ram HD trucks
   / 2013 looks to be a good year for Ram HD trucks #91
Leaf springs are horse and buggy technology. They are heavy and most of that weight is unsprung. With a typical leaf spring rear end there is no positive location of the axle, it can spring in any direction. If you think there is a cheaper suspension type than leaf spring you are dreaming. Heavy duty vehicles use leaf springs because it is the cheapest way to spring a heavy load period. I have had them sag and snap right off. Yada yada yada. ..
I disagree,
Heavy Duty is just that "Heavy Duty" No way can coil suspensions come close to leaf suspension in terms of duty cycle and load-its just not possible. I would rather go torsion suspension than coil on a heavy duty setup. If you want comfort then dont have a need for a heavy duty-its what I call a tractor :) It has a purpose rather than just going from point a to b.
   / 2013 looks to be a good year for Ram HD trucks #92
It will be interesting to find out what they did to increase the capacity of the 3500HD. No doubt it has a heavier rear axle, hopefully 19.5" wheels and commercial grade tires. Competition is good, this will make the others improve their trucks. Wonder if this truck has a longer wheelbase? You're getting into the medium duty class trucks weight ratings, probably why they don't call this a 4500 due to licensing problems.
   / 2013 looks to be a good year for Ram HD trucks #93
Dont they still have a Donkey for a hood ornament?
   / 2013 looks to be a good year for Ram HD trucks #94
I am starting to like the dodge. Even through I would never "need" it but I just like big stuff.
   / 2013 looks to be a good year for Ram HD trucks #95
mikehaugen said:
someone needs to frame this! :laughing:
True, now if only there was a way to show it on every thread like some type of signature or completely wrong and misleading avatar... ;-)
Let the towing and HP/TQ wars continue. Soon we'll all be hauling 20k lb campers with a 10k lb boat in tandem to our weekend getaways in a 10k lb diesel pickup making 1000 lb-ft! Kind of wish they stood away from DEF...
   / 2013 looks to be a good year for Ram HD trucks #96
Its not a donkey as a hood ornaments, its a Ram, and its very macho, so don't make fun of what you don't understand. :) As far as the DEF goes, I actually think its a good thing. I think it cuts back on all the DPF regens and stuff and in the long run, saves some MPG and money.
   / 2013 looks to be a good year for Ram HD trucks #97
Hey, I have no problem saying someone got it right. Big capacity, upgraded Cummins, a real tranny, ect. Whats not to like? Me personally, I don't care for the styling. Your generation Dodge to me were the best exteriors but I never cared for my 2500's interior. Dodge has made improvements in that dept also.
Chris
   / 2013 looks to be a good year for Ram HD trucks #98
I agree. It was only a matter of time for DEF.
Chris
   / 2013 looks to be a good year for Ram HD trucks #99
Dodge has been using the Ram for a hood ornament since at least the late '40's on their cars and trucks. My '12 F-450 uses DEF and so far it's a non-issue. The regens come about the same mileage but they last half as long as they did on my '08 F-450. The new Ram probably will see a mileage improvement to go along with the DEF. I'm anxious to see the specs for the 3500HD.
   / 2013 looks to be a good year for Ram HD trucks #100
I miss the when they used the actual hood ornament, instead of the badge that they use now. I had one on an '89 and it was lucky enough to not get stolen. :laughing:
2022 Case IH Magnum 340 AFS MFWD Tractor (A53342)
2022 Case IH...
5ft Set of Disc Harrows (A51573)
5ft Set of Disc...
1998 CATERPILLAR 120H MOTORGRADER (A51406)
1998 CATERPILLAR...
FAE UML/SSL 150 VT BL HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
JOHN DEERE Z530M LOT NUMBER 173 (A53084)
JOHN DEERE Z530M...
John Deere Z915E Zero Turn (A51573)
John Deere Z915E...
