Wow! I think you have me on both, although I did curl the bucket under while full up and let it down while remained curled, 700 rpm's idle speed was 55 seconds, 1500 rpm's took 25 seconds also curled while all the way up, It take more time to curl than the lift/lowering speed, there is one point ( about half way through the curl) it speeds up, Mine FEL has no float so it's all power down,
I'll need to check for just lift & lowering speed,
OK Just checked without curl and the results are 32 seconds @ 700 rmp and 17 seconds @ 1500
rpm,..
I guess this means it took 23 seconds to curl when idling, and 8 seconds to curl when at 1500 rpm's,
which is 15 seconds different between the two speeds, ofcorse they'll be some reaction time to figure in as well
I'm not sure how many GPM the pump produces, But I did install a new pump 3 years ago,
