puckgrinder85
Unless there is some other reason not to, I would. We do it around our mailbox so the plow isnt bearing down into the bank trying to push it back and ends up snapping off our mailbox.
You own to your property corners, ie on many roads ~20 ft from edge of road. The center line thing is for private roads. The state/county/city owns the ROW, and you have the right of access, or at least in Florida. You are allowed to build a driveway for instance, but it must meet there codes/specs because it is on there property. I run into people all the time who complain about grass in "there ditch." And have to explain we only stabalize "our" swale, and dont grass the for residents viewing/mowing pleasure. Im not saying I agree with making someone put in a $4500 driveway for a car port by any means just explaining some of the Why.
It seems awfully odd to worry about how much snow ends up in the ditch if it doesn't obscure visibility. That's where it will all end up anyway. I wonder if large snow berms caused the ditch to backup during the melt, and partially wash out some roads.
On our road, we used use 30-50 gallon barrels half full of rock with the post of the mailbox stuck inside. So when, not if, the snow plow knocked them down, you could "easily" put them back up. Looked like a toxic waste dump all along the hi-way though.:laughing:Unless there is some other reason not to, I would. We do it around our mailbox so the plow isnt bearing down into the bank trying to push it back and ends up snapping off our mailbox.
Think of it. The ditch is the best place for the snow as when spring thaws come it is where it should be IN TH DITCH!
Around here they purposely overplow the ditches with a side wing so that it melts there otherwise with the freeze thaws that occur overnight driving would be very dangerous.
Even on main highways the public works were out last week pushing holes in the banks because rain/freezing rain was forecast.
It could be because of road salt, or the concern that someone would take to systematically pushing snow into the ditch which would over the winter create a miniature iceberg that would clog meltwater running down that ditch and flood surrounding area. If the area in question happens to be farmed for crops spongy soil could delay accessabilty for agricultural purposes.[/QUOTE
I think you may have hit upon the neighbor who suddenly says no snow in my field. Salt contamination would kill the ground and anything in it so I could understand his rant if one year you had salted the driveway then pushed it into his field so the following year nothing grew there.
I talked to one Canadian from Nova Scotia who said the city used to haul the snow to the harbor and dump it then EPA Canada said no more it is contaminating the ocean.
