Deere manual quesiton regarding tire settings
   / Deere manual quesiton regarding tire settings #1
hotchkiss
Gold Member
Ohio
JD 6330, JD 5055e, Ford 4000,
I just purchased a 2012 6330 and when looking on line at the Deere page regarding "features", it has a subfile on tire settings. My tractor has two position rack and pinion. On the chart it give a minimum and maximum width setting. I assume those measurements are from center to center on the tractor tire rather than from outside to outside. Is that correct?
   / Deere manual quesiton regarding tire settings #2
Back when I PDI tractors for a JD dealer wheel tread settings were center to center.
   / Deere manual quesiton regarding tire settings #3
My hard copy owners manual has charts which all have in the title block "centerline to centerline". Remember now we need pictures of that new tractor or it didn't happen.
   / Deere manual quesiton regarding tire settings #4
I'm not sure exactly what it means but a tape measure could solve your question pretty quickly. I have the Disc hubs and the ears on the inside of the rim. Based on the configuration it tells you the tread setting in your manual.
   / Deere manual quesiton regarding tire settings #5
YES! it is correct
That is fair, but it isn't being delivered until the end of the month.
Agreed, I don't have the tractor or the manual yet. They were out of loaders and they will not deliver it until the end of the month. I am trying to figure out how I want it set up.
   / Deere manual quesiton regarding tire settings #8
While you wait ,and that part seems to take forever and a day, you can look up both the tractor's manual on line and the manual for the loader you ordered. Ballast requirements are there as well as tread width recommendations. The short answer is to have the rears set at the widest width for stability and and wheel weights or liquid filled plus have weight on the 3PH when doing any heavy loader work. I read somewhere that having the fronts set out to the widest width was not recommended for my 5045E but I can't find that referance now. Anyway I had them set at one position less then max which lines them up with the outside of the standard bucket. Your 6330 is of course in a whole different class and what is recommended for it is probably different. I'm looking forward to seeing the pics when you get it.
   / Deere manual quesiton regarding tire settings #9
While you wait ,and that part seems to take forever and a day, you can look up both the tractor's manual on line I'm looking forward to seeing the pics when you get it.[/QUOTE
I disagree that the tires should be set at the widest setting because that puts undue strain on the axles.
If manuals are available on line I'd think pictures also would be available on line.:)
   / Deere manual quesiton regarding tire settings #10
Not the same as having pictures of YOUR new tractor sitting in your yard with a family member smiling in the seat. We like to see the options you picked out and how it all came together.
2013 FORD F-350 (A53843)
2013 FORD F-350...
2019 PETERBILT 579 TANDEM AXLE SLEEPER TRUCK (A54607)
2019 PETERBILT 579...
2019 ALLMAND NIGHT-LIFE V SERIES LIGHT PLANT (A52706)
2019 ALLMAND...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
2015 Ford Taurus SE Sedan (A51694)
2015 Ford Taurus...
DESK (A53843)
DESK (A53843)
