Clint S
"Here's what Ithink I'd do: (1)Measure out a rope to the length of the well pipe, plus enough to hold on to. (2) Subtract ten feet, then tie on a ten foot long green pole that would sink and show a water level. (3) Run the pump till the water stopped. (4) Quickly lower the pole to the end of the pipe. (5) Pull it back out of the well. (6) If the pole was wet all the way up, I'd jump for joy and wait for the pump guy. (7) If the pole wasn't wet but a few inches, I'd lower the pipe a ways and see what happened. Note: They used to be able to pull out a steel casing and deepen a well. I'm not sure about plastic."
Good thought but most submersibles have The cable guards in the middle of this page to keep the pipe centered. Probably will not be able to get anything down there.
Pull the pump and have a well driller pump it out and determine the GPM the well makes. You could rent a pump and do it yourself, but $ may be the same
Here is the check valve I was talking about.
Torque arrestors, safety rope, and deluxe pump wire cable guards, all necessary items for installing a pump..
Here is a flow reducer
Dole flow control valves are metering valves to control allowing only a specified amount of water per minute through the valve.
Seems if you were pumping dry you should have spits and sputs of air. Not just a gradual reduction of pressure till none. Bad foot valve would not run out of pressure or water just cause some air to get in the line. Once you were running you would have water until you shut it off and it water leaked back, that's why most folks but in back flow valve I posted above for just in case.
Here is a potential scenario, although it is probably not happening and is full of what if's it in theory could happen.
Split in the line below the water level.
IF you have a backflow valve before the gauge house would hold pressure. If it is under the water line in the case the pressure of the water in the line may not be enough to negate the pressure of the water in the casing holding the water in the pipe. With all the water off in the house the pump may have enough juice to fill the pressure tank AND pump water out of the split in the pipe. Once the pressure tank is filled the pump will shut off, you will not lose pressure due to the backflow valve. At my place I can run the water for several minutes or flush the toilet 4 of 5 times before the pump kicks on. With the house calling for water AND the split in the pipe the pump cannot keep up and you lose pressure.
Again this is a far fetched scenario, and probably not happening. My physics may be off too, but I had something similar happen and I would lose pressure after running water for a while. I would never lose water all the way just pressure down to a small 5 to 10 PSI. It was a split pipe below the water level.
I would have the well tested for GPM and go from there. You may just have a defective pump that heats up and loses power. You say the pressure "shoots up"
When you have water how long does it take to build up and shut off. At my house it takes 20 seconds or so to go from 30 to 50
