Kubota bh 92 backhoe attachment
   / Kubota bh 92 backhoe attachment #1
phastmac
Hackett, Arkansas
Kubota M7060,Kubota MX 4700hst, Kubota B7100hst, Kubota RTV 900,
I have a Kubota MX 4700 I am getting ready to put a bh92 backhoe attachment on it. My tractor has the HST transmission. I was curious as to how high the rpms need to be to operate the backhoe effectively? Any info would be appreciated.
   / Kubota bh 92 backhoe attachment #2
I generally run mine at 1500 - 1600 rpm. I am very oppressed by how well the BH92 digs.
I was hoping it would run ok with lower rpm. Less fuel and quieter with lower rpm. Thanks for the info.
   / Kubota bh 92 backhoe attachment #4
I could move loose dirt from one pile to another with lower RPM, but for actual digging I usually run at about 2000 RPM. It does suck down fuel, but you can get a lot done in an hour or two. We have a lot of rock, and to move the bigger ones, I go all the way to rated RPM. It is unfortunate that you cannot reach the throttle from the BH seat. If you have rock, get the hyd. thumb if you can possibly afford it. It is one of the best tools i have.
I did get the hyd thumb. That is going to be very handy. thanks for the info.
   / Kubota bh 92 backhoe attachment #6
Mine operates just fine digging at 1500 rpm. I just finished this trench about 250' long 4 - 5 feet deep through hard clay and shale. The machine performed perfect.
very good.
   / Kubota bh 92 backhoe attachment #8
If you are just getting started with using it, you'll actually benefit from having the rpm's below 2,000. The hydraulic pump puts out adequate pressure to run the hoe, but not quite so much output in gallons/minute, so everything operates with good power, just a little slower. Until you master the joysticks, that allows you to run the backhoe more smoothly. With mine, 1,600-1,700 on the tach is kind of a sweet spot for backhoe operation.
Makes sense. I probably will do what do suggest. Slower movements will help this rookie. Thanks
   / Kubota bh 92 backhoe attachment #10
1500rpm seems to work very good for me, anything less and its just to slow to get things done, Picture 002.jpg
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
Club Car Electric Golf Cart (A50121)
Club Car Electric...
3pt Cult. & Pipes (A50121)
3pt Cult. & Pipes...
2017 POLARIS RANGER 570 4X4 PROSTAR UTV (A51406)
2017 POLARIS...
2007 Ford F-150 Crew Cab Pickup Truck (A50323)
2007 Ford F-150...
Honda HT3813 Riding Mower (A50121)
Honda HT3813...
