Build a set of steel wheels Save my rubber
   / Build a set of steel wheels Save my rubber #41
Wondering if the tracks on Cat Dozers ever have to be replaced?:D
Yes! And way more often than most people think.
   / Build a set of steel wheels Save my rubber #42
If there really Amish or Old order they dont have tractors? Sure your not talking menonites?
Yes Amish. Depends on group and how strict they are.
   / Build a set of steel wheels Save my rubber #44
There is a tractor near us that has pieces of steel pipe slid over the rear wheels them (ie: they deflated the rear wheels, slid the pipe over the wheels, then re-inflated the wheels). Something like that might be worth it if you could find the right size pipes and weld or bolt cleats onto them.
That one is setup as a roller (ie: the pipe on the rear wheels is ~4' wide and there are pipes on the front "trike" wheels that fill up the center gap)
Aaron Z
   / Build a set of steel wheels Save my rubber #45
The neighbor replaced the tracks on his small deere 6-way dozer and it cost him $20k.
   / Build a set of steel wheels Save my rubber #48
Who ever said they were better ???? I never said they were better ! Never said I had no use for rubber ! Never said that ! Steel wheels don`t go flat ! That is all ! and I like these !!!!!!!!!!!!! that`s all !
   / Build a set of steel wheels Save my rubber #50
Yea and them on a d4 sized machine i think are something like $30k! to replace.
Never seen an old dozer with worn out tracks? The verticle nubs that hold the ground or whatever get so flat that they look like track hoe tracks, or ar almost smooth!!
2011 Ford Crown Victoria Sedan (A54815)
2011 Ford Crown...
2019 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A56138)
2019 INTERNATIONAL...
2009 INTERNATIONAL PAYSTAR 5600I FLATTOP SLEEPER (A55745)
2009 INTERNATIONAL...
2016 Ford SD Dump Truck (A52377)
2016 Ford SD Dump...
2016 Ford F-150 4x4 Pickup Truck (A54814)
2016 Ford F-150...
2017 PETERBILT 579 DAYCAB (A55745)
2017 PETERBILT 579...
