6th Grade science project using .22
   / 6th Grade science project using .22 #1
tornadowatchranch
NE Kansas
Bobcat 335 for the fun stuff JD gt235 for the lawn
Hey all
I have gained so much from you guys over the years I thought I would offer up an idea.
For my son's 6th grade science project we decided to test mass and inertia by using a .22. We got 5 different weights and FPS of .22 ammo at the gun show and shot them into the thickest book the DAV had. He measured how far into the book each projectile penetrated (this one went to page 687, this one to 1254, etc). Some of the aguilar ammo is all the way down to 20 Grain and 550FPS.
His teacher is super cool and wanted us to specifically point to the safety aspect of the preparation. We included hearing/eye protection and an adequate backstop.
He came up with the idea about a week after Sandy Hook. I was a bit surprised it was approved. We live in a semi-rural area so that likely helped.
I just thought I would offer it up in case anyone else needed a project idea.
Have a great day
   / 6th Grade science project using .22 #2
Awesome, and kudos to the school for seeing the educational benefits proper use of guns can have on students!
   / 6th Grade science project using .22 #3
Ah....
Ok....
Lets see the numbers and his report! :laughing::laughing::laughing:
You can't tell us about the experiment without showing the results! :D:D:D
Later,
Dan
   / 6th Grade science project using .22 #4
Sandy hook
   / 6th Grade science project using .22 #5
In the "Olde" days and I do mean "Olde" days, before any kind of electronics. they measured velocity with a thing called a Ballistic Pendulum and a lot of mathematics. The idea was you fired a round at a pendulum of steel of a known weight, on a knife edge "bearing" and attached to the pendulum was a cloth tape measure that when the pendulum moved backwards it drug this cloth tape measure thru a slot and of course when it moved the other way the cloth tape measure did not move backwards. You then read the tape measure to determine how much the bullet moved the known weight pendulum and from that you could calculate with a given bullet weight what the energy was striking the pendulum and work backwards to calculate the velocity of the bullet.. All very imprecisely I might add..
James K0UA
   / 6th Grade science project using .22 #6
That would not go over well here in Maryland :shocked: where we had a child suspended for chewing a pop tart into the perceived shape of a gun.
I am glad your school and teacher obviously has som common sense...
   / 6th Grade science project using .22 #7
Sandy hook
If that's all you can come up with, why bother, unless you're just wanting to up your post count? Senseless, out of place and totally out of context!
   / 6th Grade science project using .22 #8
That's great, I am glad it is still accepted in some areas. I live in a rural area and my daughter teaches in a nearby school district where I believe it would be acceptable. The hysteria that seems so prevalent in many areas is not universal fortunately.
   / 6th Grade science project using .22 #9
Are you really testing just mass and inertia? I would think the shape/profile and composition of the bullet would also have an affect on penetration that isn't being controlled for in the experiment perhaps. I am assuming those things can vary slightly from one load to another.
   / 6th Grade science project using .22 #10
Sandy hook
I "think" he meant that in the original post, Tornado wrote Sandy something else-it has since been edited to say "Sandy Hook"
But, R8nger sure could have written just a few more words to explain that and not appear to be a hit-n-run poster...
HOBBS MODEL-666 6 ROW PEANUT RESHAKER (A54756)
HOBBS MODEL-666 6...
5' BOX BLADE W/ SCARFIER (A54756)
5' BOX BLADE W/...
2019 FORD F250 XL EXTENDED CAB TRUCK (A51406)
2019 FORD F250 XL...
KUBOTA M7-132 LOT NUMBER 31 (A53084)
KUBOTA M7-132 LOT...
2018 JCB Truss Jib Telescopic Hydraulic Boom (A53421)
2018 JCB Truss Jib...
Hutchinson 10x71 Transport Auger (A50775)
Hutchinson 10x71...
