4035 spits and sputters at high rpms
   / 4035 spits and sputters at high rpms #1
jjlite
U.P. MICHIGAN
mahindra 4035
Been creeping around this site for a while and there is tons of great info here!! so I said to myself.Self you should get some advice. I have a brand new 4035 and have been moving snow with it all winter and its been doing a heck of a job!! The other day I was messing around in the back yard and ran the rpms up to the pto mark and the thing started to spit and sputter backed off and she purred like a kitten.I ended up shutting the tractor off and restarting it and it ran fine for a while then back to spit. Any input may be helpful thanx in advance!!
   / 4035 spits and sputters at high rpms #2
Is your fuel gelling? If it's cold outside the diesel fuel will gel and could cause this to happen, put some diesel fuel additive like 911 in the tank and run it low idle for a bit then see what happens, should check the fuel filter also, have you done the 50hr. Maintaince yet ?
At the time it was very cold around 10f and I have not been out to give it another try.As far as the 50hr maintenance she only has 10-15 I will give the 911 a try. thanx
   / 4035 spits and sputters at high rpms #4
Does your tractor act up after twenty minutes or so, and run rough with puffs of whitish grey smoke at mid to high RPM? I suggest you contact your dealer, as the unit must be still under warranty. Describe the problem and ask to have the timing adjusted. Yours is a common problem with tractor using this particular Bosch injection pump, and 50 to 100 hrs is typically when it it will first appear. The pump timing needs to be advanced a tiny bit and the problem will go away. Fuel restriction between supply and pump can also cause the flutter, but if it's timing related, the engine will run fine for twenty minutes. The cold start timing advance built into the pump is controlled by a timer on Mahindras, and runs for approximately twenty minutes each time the engine is started. When the timer turns off, the sputter begins. Shut the engine off, restart, and it runs fine again for twenty minutes. Sound familiar?
Thank you Harry in Ky that is exactly what happens !! Just came in from running her and timmed when it starts and it is around the 20min mark.Going to get ahold of the dealer this week and run it by him.I have to get this taken care off before all this snow melts and the feilds dry up around here.
   / 4035 spits and sputters at high rpms #6
Had the EXACT same problem on my 4035...recommend you change the fuel filter, that was the culprit in my case...no problems since the change...
Rich
Talked with my dealer yesterday and they suggested the same so new filter and fuel its.Just seems odd that it will run great at 2200-2400 rpm for so long before it acts up I would think that if it were water or fuel it would happen right from the go. We give it a shot. thanx.
   / 4035 spits and sputters at high rpms #9
Yeah, seemed odd to me as well...but it worked...hope it does for you too..please, keep us updated, thanks...
Rich
Thanks Rich will keep all updated. things hear move slow and working 6-12s on nights for the next couple of weeks.
2016 Ford F-450 Crew Cab Knapheide Service Truck (A52377)
2016 Ford F-450...
2023 Vivid EV Golf Cart (A51694)
2023 Vivid EV Golf...
Informational Lot - Shipping (A53473)
Informational Lot...
2011 Land Rover Range Rover Sport AWD SUV (A51694)
2011 Land Rover...
2023 Evolution Classic 4 Pro 48V Golf Cart (A53002)
2023 Evolution...
UNUSED HURRICANE D6028 JOB BOX (A51248)
UNUSED HURRICANE...
