Smoking a Turkey
   / Smoking a Turkey #1
2LaneCruzer
Super Member
Oklahoma
John Deere LX172
Aaarrrggg! Sharn Jean volunteered me to smoke a turkey for Easter, on the Big Green Egg. Last turkey I smoked was over 40 years ago...I need some suggestions, especially from someone who has had spectacular success with a spectacular method and recipe. Anyone?
Thanks,
Dennis
   / Smoking a Turkey #2
Look for a brine recipe online and brine the bird before smoking.
   / Smoking a Turkey #5
I don't often smoke a whole bird, but I do a lot of turkey breasts.
Most of the time I use soaked apple wood for smoke flavor, all of us, and the extended family, seem to prefer the apple over other wood smoke flavors. I put one good sized chunk directly on top of the coals and then put a filled metal smoke box next to it so the smoke lasts longer.
I only rub poultry seasoning over the dampened breast an hour or so before I put it on the smoker. Stuff the cavity with a good Vidalia onion.
For a hot smoker, I like to have a water pan beneath the grill, pour 1/2 bottle of cheap wine in with the water and a couple of bay leaves. Still can't remember why the bay leaves, something Mom did and Moms are never wrong!
For cold smoking, I keep adding apple wood chunks to the coals over the course, no water pan
I also like using briquets for smoking because they tend the burn at a better controlled rate and don't need as much tending to versus lump. Now, if I'm grilling a steak or burger, lump is the only way to go.
My bottom line is that it's really hard to mess up on smoking a turkey, they always come out better than one baked in an oven.
   / Smoking a Turkey #6
When smoking do you use bark also or only the wood. I have a lot of apple wood from pruning just wondering if I need to shave it off?
   / Smoking a Turkey #7
I always peel my smoking wood before I cut it up into pretty hefty chunks, don't know why, but I do.
   / Smoking a Turkey #8
I have an electric smoker with wood chip container at the bottom that dumps them right on the heating coils. I bought the smoker at Sam's Club about 4 years ago. It is big enough to smoke 2 whole turkeys and a rack of ribs at the same time. I set it a 250-275, fill the chip container once and let it smoke for a couple hours, then fill it again then just let the birds set for 4-6 hours. Meat falls off the bone and has a nice brown smoke outside. Wife uses the Cajun Injector system to load the turkeys with seasoning on the inside. I usually do one only on Thanksgiving and Christmas as I don't care much for turkey. Slow cooking some pork ribs or brisket is more to my liking. I had the charcoal smoker but didn't care for it as you had to constantly load fresh charcoal and no way to control the heat. I love the electric set it and forget it temperature and timer.
   / Smoking a Turkey #10
If you can get some black cherry, it's pretty good, too.
2012 SOUTHERN 130BBL VACUUM TRAILER (A53843)
2012 SOUTHERN...
2014 Ford Taurus AWD Sedan (A54815)
2014 Ford Taurus...
12ft Heavy Duty Aluminum Ramps (A55301)
12ft Heavy Duty...
