Hydraulic Issues - Diagnostic help
   / Hydraulic Issues - Diagnostic help #1
sruman
Shermans Dale, PA
Ford 1910
I have a Satoh 650 and I have a unique problem that is occurring, and not sure the answer. I've read many many threads, but cannot find a reasonable answer/assistance with my particular issue.
First, my tractor has rear draw bar and a front loader. It has the separate control units for each (rear draw bar is standard, like is on all models). The valve control assembly for the loader may or may not be orginal. Not sure.
The issue is this: When i raise the draw bar (demand fluid), my levers on the loader valve control snap forward, dump and lower the loader. This continues to happen until the bar is raised to the required height. It seems to me (backyard mechanic) that when the bar is raised and demands fluid, it is pulling from the loader control valve assembley, causing the loader to dump and lower. Here are some other facts to help with diagnose the issue:
* Only occurs when bar is raised.
* Loader works fine when used independently.
* Lowering bar has no effect on loader or control valve assembly.
* Fluid levels are good.
* Filter is clean.
* Speed on bar and loader (up and down) are good (good pressure).
Is there a check valve or something in place to prevent this? Can you help pinpoint the issue any further?
Thanks in advance.
Matt in PA.
   / Hydraulic Issues - Diagnostic help #2
Matt, I will try to help-but lets get some terminology straight first:
The "drawbar" you are referring to is really the 3 Point Hitch (3PH). A drawbar is fixed, and used to tow wagons and trailers-it's usually a thick metal bar that extends out from under the rear transmission case.
The valve the controls the 3PH is usually called the "rockshaft" lever/valve.
You stated "good pressure", did you test it? If so how?
How many hoses are connected to the valve body that operated the FEL (front end loader)? 6 or 7?
Can you take pictures of how it's (the FEL valve) is plumbed to the tractor?
I suspect that the FEL valve is plumbed in "parallel" with the 3PH, but I am not familier enough with your machine to know for sure yet.
Thanks for setting me straight. I'll get the pictures to you tonight.
You are correct. Not a draw bar, but the 3PH "bar".
Good pressure due to the fact that the speed of hydraulics is fine, nothing else. No official pressure testing.
As noted, stay tuned....news at 8.
Thanks.
First pic is the FEL controls. There are six hydraulic lines. Two run to the top of the hydraulic "cap" by the rockshaft (pic 2). they other four run to the FEL cylinders. IMAG0013.jpgIMAG0014.jpg
Question, could the hydraulic "distributor" be clogged or something, causing the draw of fluid from the FEL valve control? Just a thought.
   / Hydraulic Issues - Diagnostic help #5
I dont have a loader on my 650, so I cant be of much help!---sorry! thanks; sonny580
   / Hydraulic Issues - Diagnostic help #6
I am not sure what the "distributor" is so I can't help with that. Is this a new problem to has it always done this (at least as long as you've owned)? I am trying to think of how lowering raising the 3PH will trip the FEL valve, so yes I am stalling a bit.
   / Hydraulic Issues - Diagnostic help #7
sruman,
While operating the 3PH and the FEL controls move can you try moving one of the FEL controls to see how force it takes to move them back to center. This might give us a clue.
Also are the handles being pushed away from the valve body or pulled towards the valve body when this happens?
   / Hydraulic Issues - Diagnostic help #8
I added some labels to the first picture.
What is the "OUT" hose connected to?
Is there a tee connector on either hose from your other valve?
See Picture (drawing) attached. This may help us get a clearer picture on the hydraulic system. Pretty basic.
oldnslo: to answer your question, it takes ALOT of force to move them, barely humanly possible. The handles are being pushed toward the front of the tractor (away from driver).
kennyd: The fluid distributor is a "box" that the power steering lines ties to. Nothing more than that (see pic).
By looking at the pick, I think the line 2 (from box B to D) is either clogged, or the distributor (Box B) is clogged. Reason: when I raise the 3PH, rather than fluid come from distributor box (Box B, line #2 on diagram), is it sucking the fluid from FEL Control (Box C). I cannot think of any other reasonable explanation. Again, I'm no mechanic, but it makes logical sense to me. Unless anyone has a better idea, I'm going to tear apart that box and line and make sure they are clean.
2015 FREIGHTLINER CASCADIA (A53843)
2015 FREIGHTLINER...
2018 Chevrolet Equinox AWD SUV (A53424)
2018 Chevrolet...
2013 F-550 Bucket Truck (A55218)
2013 F-550 Bucket...
2015 Chevrolet Silverado 3500HD Ambulance (A52377)
2015 Chevrolet...
2019 Kubota SVL 95-2 (A47477)
2019 Kubota SVL...
2000 JOHN DEERE 444H WHEEL LOADER (A52705)
2000 JOHN DEERE...
