Care and Feeding of welding helmet
   / Care and Feeding of welding helmet #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
So how do you guys keep your glass (Plastic) clean? Do you store your helmet in such a way it gets some light so the batteries are up to snuff when you grab your helmet?
   / Care and Feeding of welding helmet #2
I only use flannel cloth to wipe my welding lenses. My auto lenses are solar powered. I just hang the one I'm using on a hook near the welding table in front of a space heater. Here in the north west fogging is always an issue. You can see it in the back ground of this picture.
   / Care and Feeding of welding helmet #3
My shop stinks compared to most other peoples. I do my welding outside, but my welder lives in a ratty old barn that has part gravel floor and part dirt floor and is drafty and even leaks in spots. I use an old metal file cabinet that someone tossed out by the road (freebie) to store my welding leathers, welding gloves, welding helmet, safety glasses, and even my clear plastic grinding shield. Keeps everything reasonably clean considering the circumstances. The helmets fit nicely in the big square drawers.
I do not use auto-darkening helmets though - still use just old school flip hoods.
   / Care and Feeding of welding helmet #4
Pledge multi surface spray and micro fiber. I hang them up high enough that they don't get too dirty when not in use
   / Care and Feeding of welding helmet #5
Just dont step, sit or drop anything on it and you'll be fine;)
I usually put mine in a window although it is battery/solar powered.
I clean mine with windex.
   / Care and Feeding of welding helmet #6
Some people say putting an auto lens in the sun will recharge the solar cell. It might but it won't recharge the batteries if your helmet has both. Liquid soap and lots of water and then a soft cloth to dry.
   / Care and Feeding of welding helmet #7
I always assumed the batteries got plenty of UV from the arc. If I ever left the hood idle long enough that the batteries were fully discharged, I'd worry, but as long as there's enough charge to get the first five minutes of welding, I figure the hood is topping off from the arc, not running down.
   / Care and Feeding of welding helmet #8
One of the guys at work says the arc doesn't produce UV rays. Apparently some owners manuals say to place the lens in the sun to charge the solar cell. I never had an auto dark helmet but I have used one. I think it would be a fun experiment to see how the new generation welders, with the auto helmets, would do with a conventional helmet having to nod their head to get it to come down. I think it would give some of them a new respect for the old school welders. ;)
   / Care and Feeding of welding helmet #9
I've been using an auto lens for almost 2-years now. I still lift my hood after every weld. Hard habit to break I guess. Auto lenses are nice for when you drop the hood, you can find the exact place to start, less chance of chicken scratches outside the weld zone.
   / Care and Feeding of welding helmet #10
I have used auto dark hoods since 1991 (first one was a SpeedGlas with batteries) but now I just buy the cheap HF freight models and they seem to work just as well. I was storing mine on the wall hanging on a screw but after about a year it got to where the battery wouldn't stay charged so I rigged up some wire on my garage door so I can hang it in front of a West facing window and now it stays charged up. Before it would be dead and the first few arcs you struck would not darken till the UV light from the arc charged it up enough to darken (a second or so) It still has UV protection even though it isn't dark so it wont harm your eyes, just gets pretty bright for a second.
1987 LANDALL 48ft 35 Ton Hydraulic Slide Axle T/A Drop Deck Trailer (A51692)
1987 LANDALL 48ft...
Miscellaneous Pallet of Road Safety Signage (A52384)
Miscellaneous...
2005 INTERNATIONAL 4300 24FT BOX TRUCK WITH TRANSLUCENT ROOF (A54313)
2005 INTERNATIONAL...
2016 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2016 Ford F-550...
2004 Stage Line SL-250 Mobile Folding Stage Trailer (A50322)
2004 Stage Line...
2003 Ford F-350 King Ranch 4WD Pickup Truck (A53117)
2003 Ford F-350...
