Ridding deck of wasps!
   / Ridding deck of wasps! #11
remove a deck board, using a mirror locate all the nest you can see from that point. Should be able to spray from the opening. Move over to another area and repeat. Replace boards with screws to make it easier next time.
   / Ridding deck of wasps! #12
Ortho Wasp and Hornet killer works well.
I had the same problem on my deck which was built a couple of inches over a concrete pad. I tried a propane fogger with insecticides. It did nothing. Since the boards are spaced one inch apart you can't get anything under there to spray the nests directly even if you knew where the nests were. There is no one entrance or exit to trap them as there are hundreds of feet of spaces between the boards. Just spraying insecticide down the cracks won't hit the nests because they are on the bottom of the boards.
I finally solved the problem by tearing down my deck. :(
Finally someone who understands the situations... Thanks! Although your solution isn't very viable right now. lol... I'd hate to rip it all down. I'm going to try a couple wasp hotels to see if it helps at all.
   / Ridding deck of wasps! #14
feed em.
ie. bait granuales.
could also take a da and run a 'tubes in t he wall' system.. ;)
   / Ridding deck of wasps! #15
Go out at night when they are all home at the nest. Bag the deck with 4 mil plastic vapor barrier and fumigate it.
I'm skepticle about the soap and water advice. As I understand it, that's more for leaf eaters.
You spray it on the food (plant leaf). The bug eats it along with the leaf and craps himself to death, dying of dehydration.
Ammonia is great, but you have to suffocate them with it. So spray directly on the nest for best results.
If I need a bug killer for my plants (or engine degreaser) I mix up a 50/50 of ammonia and water with a good dose of dish soap. Apply directly to the bugs. What the ammonia does not get, the soap will.
   / Ridding deck of wasps! #16
I had the same problem at my place. Had an exterminator come out and spray all around the house and between the slats of the deck, and it did the trick. I don't know what he used, but when he did it he said that he couldn't guarantee the results as he was unable to spray the wasps directly. It worked though and I have not had a problem for the past couple of years.
   / Ridding deck of wasps! #17
Tig's answer was right on. For some reason, my first tractor, a JD 420U was loved by wasps. Never could find the nest, but they were there, year after year. After a couple years, I covered the tractor, set off a bug bomb under it and next day there were a dozen or so dead wasps on the ground under it and I didn't have any more wasps flying around when I fired up the tractor.
   / Ridding deck of wasps! #18
Permethrin-10 concentrate, mix as directed in the highest recommended strength. Use a pump sprayer and a leaf blower. Tape the sprayer wand to the leaf blower nozzle to make a super fogger. Have at them. Take your time to fully treat the affected area. Also works to fog the yard for mosquitoes or treat tall trees and buildings.
   / Ridding deck of wasps! #19
I have to ask...there seems to be a regional difference in what are known as "wasps" vs. "hornets". Up here the wasps are the dark mud-tube building things and I've never known them to hurt anybody. Hornets on the other hand are the long-bodied "yellow-jackets" or their smaller cousins that live underground.
   / Ridding deck of wasps! #20
Here we call ones that make a mud nest "mud daubers" or "dirt daubers" and they don't usually sting. The ones we call wasps make a paper nest with lots of cells and furiously attack when provoked. Photo is a wasp nest.
2024 Wanco WCTS-SM4A-730 800W Solar Integrator Trailer (A51691)
2024 Wanco...
2016 Dodge Caravan Van (A53424)
2016 Dodge Caravan...
2025 K5436 UNUSED (5) Wire Mesh Panels (A53117)
2025 K5436 UNUSED...
2008 Ford F-450 14FT Flatbed Truck (A51692)
2008 Ford F-450...
JOHN DEERE 408R (A53084)
JOHN DEERE 408R...
1273 (A50490)
1273 (A50490)
