Everything Attachments NEW HD Box Frame Disc Harrow
   / Everything Attachments NEW HD Box Frame Disc Harrow #1
EverythingAttachments
Elite Member
Newton NC
Which One do you want to know about?
Here's a sneak peek at yet another exciting new attachment from our plant right here in Newton, NC. The pictured harrow is our new 20x18(20, 18" blades) 72" disc harrow which shares the same frame as our smaller 16x18(60") model. We will also offer a 24 blade model that has an even heavier frame. Most models will be available with the option of 18" or 20" blades depending on your preference. These harrows are quick hitch compatible and they also feature an easy to use screw-type adjustment that eliminates the need to pull pins and struggle to change the angle of the gangs. I will provide a link to the product page(with prices and specs.) when we get these added to our website.
Our Everything Attachments harrows will be BY FAR the best value on the market which is our goal with every single attachment that we make!!!! FREE SHIPPING ON EVERYTHING!!
Purchase direct from the manufacturer.....NO DEALERS, NO DEALER REPS, NO DISTRIBUTORS...........AND THE WINNER IS YOU!!!!
Click to enlarge
   / Everything Attachments NEW HD Box Frame Disc Harrow #2
Sweet!
One of these years, I'm going to have to plan my vacation around visiting you guys ( and several other TBN favorites). I fear though that it will be a really expensive vacation!
Come on down!! Below is a finished 24x18 harrow that is ready to be loaded for the show in GA. It features a heavier frame and double U-bolts on the gang hangers.
   / Everything Attachments NEW HD Box Frame Disc Harrow #4
Very nice. Your new disk and two bottom plow are on my need to have attachment list.
Here is the video we made about our larger harrow:
   / Everything Attachments NEW HD Box Frame Disc Harrow #7
I was the lucky one that was able to get the first 24-20 EA built, and had a chance to pull it this past weekend with my kubota mx5000. I was a little worried that i did not have enough tractor. the kubota grunted a bit but I was able to it moving in a sandy base. With the front set at nearly full angle and the rear slight less, it cut very well. I was in more of a sandy field putting in a food plot and it was to able to produce in one cut that the old angle iron harrow would take 3-4 passes. It impressed everyone in our hunting club.
The only thing I would look at is the spacing on the inside of the c channel drop hanger to the next disc. It is very tight and hard to get grass/vines out. There is barely enough room to even get your hand in there, since EA uses c-channel and the rest of the manufactures use flat bar for their drop hangers.
Great product and very well built.
I'm glad you like your harrow and we appreciate the business! These new disc harrows are getting plenty of attention because they're a step above any 3pt model on the market. We did have to sacrifice some clearance in using those hangers but I think that design will greatly increase the durability and life expectancy.
2018  FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52141)
2018 FREIGHTLINER...
2025 12V Diesel Pump and Hose with Meter (A50324)
2025 12V Diesel...
2016 Ford F-350 Ambulance (A51692)
2016 Ford F-350...
2014 International DuraStar 4300 Terex BT3063 30,000LB Crane Truck (A48081)
2014 International...
48" Pallet Forks  (A52384)
48" Pallet Forks...
2016 Nissan Murano SL AWD SUV (A50324)
2016 Nissan Murano...
