Jacobsen turfcat DW224 leaking power steering cylinder.
   / Jacobsen turfcat DW224 leaking power steering cylinder. #1
DW224
Plattsburg, MO
Jacobsen DW224
Jacobsen turfcat DW224 power steering cylinder leaking. Has any one found an off the shelf replacement for this cylinder. Jacobsen wants almost $800.00 for their OEM part number.
   / Jacobsen turfcat DW224 leaking power steering cylinder. #2
Have had it to hydraulic shop for new seal kits twice and after reinstalling it on mower it starts a slow dripping leak when turning wheel either direction.
   / Jacobsen turfcat DW224 leaking power steering cylinder. #5
Do you think they tested the cyl before returning it to you? If so, it should have been stated.
There are people that will do a repair and just that.
You would think someone would test a repair work to see if it did what the customer wanted.
They tested it with air pressure.
   / Jacobsen turfcat DW224 leaking power steering cylinder. #7
At what air pressure.
A hyd cyl that won't leak at 200 lbs of air pressure is no indication it will not leak hyd fluid at 1500 psi.
steering 001.jpg Picture of cylinder. Any possible way to find a universal replacement ??
steering 003.jpg Another view of cylinder from other side.
UNUSED FUTURE SKID STEER QUICK ATTACH LAND LEVELER (A51244)
UNUSED FUTURE SKID...
John Deere 980 Field Cultivator (A50514)
John Deere 980...
2014 UTILITY 53X102 DRY VAN TRAILER (A52141)
2014 UTILITY...
Kubota L2800 (A47384)
2017 Ford F-450 Altec AT200A 36ft Bucket Truck (A50323)
2017 Ford F-450...
HONDA FOURTRAX 300 FOUR WHEELER (A51243)
HONDA FOURTRAX 300...
