Need ideas on moving a 250 gallon propane tank.
   / Need ideas on moving a 250 gallon propane tank. #1
zene55
Dripping Springs, TX
Kubota L2800
I need to move a 250 gallon propane tank from my ranch to my mothers house 3 hours away. My tank is on a concret skid and not hooked to any thing. It shows a 30% level on the gauge. My request is I need a few questions answered and haven't found any answers yet.
1. Is it possible for a propane company to come out and reclaim the propane?
2. Would be be a bad idea to transport the tank with the 30% level in it?
3. Any idea what the capiacity of my Kubota L2800 FEL is?
4. I guess that the tank weighs about 900-950 lbs.
Any suggestions?
   / Need ideas on moving a 250 gallon propane tank. #2
Throw a few chains on it and lift it on the trailer chain and strap it down and go ,also make sure your insurance is up to date !
   / Need ideas on moving a 250 gallon propane tank. #3
Thats what I did --but I didn't move it 3 hours away either....just chained it down to the trailer and took it. Not sure about the legalities.
   / Need ideas on moving a 250 gallon propane tank. #4
It most likely will need DOT Placards among other regulations for over the road movement AND there are hefty fines for not doing it legally!!
   / Need ideas on moving a 250 gallon propane tank. #5
Throw a tarp over it and drive normal ,but if you have an accident make sure it's your mother in laws truck !
   / Need ideas on moving a 250 gallon propane tank. #6
Any suggestions?
Yes, hire a propane company to move it for you. If you will be driving on any federal highways and get caught transporting a tank with 30% LPG, you will be in deep trouble.
As for checking the status of your insurance, don't bother. There is likely an exclusion in the policy that covers this situation.
   / Need ideas on moving a 250 gallon propane tank. #7
I had a 500 gal tank moved 30 miles across state lines. I hired a contractor that charged $50, he had a hazmat endorcement, and placards. There was 70% in this tank.
If it is empty, and puged,the dot said, I could hall it. Most propane suppliers can empty your tank.
Dave
   / Need ideas on moving a 250 gallon propane tank. #8
Dot law states that you don't need hazmat or placards for less than 999 pounds, your right under that, I believe.
   / Need ideas on moving a 250 gallon propane tank. #9
Good advice. You need a special endorsement on your commercial drivers license to haul propane. Also, there are no anti-slosh baffles in a propane tank. Slam on the brakes and things will get really interesting. Talk to your local propane dealer about emptying the tank. They might like it if you could use your tractor to roll it over for them so the valve was on the bottom.
Do you think the Kubota can lift 900 pounds?
2017 FORD F-550 XL SERVICE TRUCK (A51406)
2017 FORD F-550 XL...
2007 FONTAINE TRAILER CO. 48X102 SPREAD AXLE STEPDECK (A52472)
2007 FONTAINE...
INSPECTION (A51573)
INSPECTION (A51573)
2015 Ford F-450 Knapheide Service Truck (A51692)
2015 Ford F-450...
(1) HD 27ft x 24ft Full Garage Kit Metal Building Frame (A51573)
(1) HD 27ft x 24ft...
2010 Hyundai Elantra Touring Sedan (A51694)
2010 Hyundai...
