Valve stem/tire warranty question
   / Valve stem/tire warranty question #1
PumpingPete
Fort Scott, KS
New Holland Workmaster 55
As I was mowing today, I noticed a loud hiss coming from the left rear tire. When I stopped and checked it out, I notice the air was coming out of the valve stem. I couldn't get it stopped unfortunately and had quite a walk back to the truck. Anyways, my question is concerning the warranty on tires. I have had this tractor only a couple of months. Is this something new holland covers under their warranty?
   / Valve stem/tire warranty question #2
You would think so. Is there a u shaped guard on the rim?
I didn't notice one. I have already called the tire shop to place a service call, but didn't know if I should be speaking with the dealer instead.
   / Valve stem/tire warranty question #4
I seriously doubt that New Holland will warranty the valve stem.
I figure it is a long shot, but could have swore I was told the tires had a warranty as well.
   / Valve stem/tire warranty question #6
Around here, some tractor dealers don't do tires, they send you to a local Ag/Industrial tire shop warranty or not. The valve stem probably is a long shot, but it can't hurt to ask.
   / Valve stem/tire warranty question #7
it's such an easy fix if it is a tubless tire.. snatch old stem.. use a squeezevplunger tool to stick a new one in without even debeading tire.....
Where do you get one of these plunger tools?
   / Valve stem/tire warranty question #9
my local tire place uses one. it's some kind of forcing cone. they lube up a vs. cram it in this tapered tube. shove the tube to the hole. do a fast move and grunt, then pull pack and there is a valve stem in the hole.
the remov ethe old one first with a 2 claw tool like a small hammer. it comes out.. thus it can go in..
I have seent hem on the internet too.
can do a valve stem in like 30 seconds, no debead...
   / Valve stem/tire warranty question #10
rear tire wont have rubber valve stem. more than likely hit something and broke it. break one side down to replace 30 min job
2013 PETERBILT 389 (INOPERABLE) (A55745)
2013 PETERBILT 389...
2016 Dodge Ram 5500 4x4 Crew Cab Stellar 4421 4,000lb 2 Ton Crane Service Truck (A55973)
2016 Dodge Ram...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
DRAFTING TABLE (A58374)
DRAFTING TABLE...
2013 Ford F-450 Utility Flatbed Truck (A55973)
2013 Ford F-450...
Bucket (A55973)
Bucket (A55973)
