I am in the process of finalizing my third (and hopefully last) dump trailer purchase.  The previous two dump trailers I have owned were both scissor lifts and they seemed to work fine.  However my second dump trailer (a 7'x14' Moritz) has been a great trailer but I have to be careful not to load to much fill at the front of the trailer as twice I have had to shovel some material out of the front before it would dump.  It seems to me that a telescoping cylinder at the front of the trailer being ahead of all the weight would be better able to dump a heavy load since the scissor is mounted in the middle of the bed and so the material at the front has more leverage on the hoist mechanism.  However with a telescoping cylinder there are a lot more seals to worry about so I wonder if long term it might be problematic.  I have dumped hundreds of loads with my scissor lift dump trailers and never had a leak.  What are your thoughts on scissor lift versus telescoping cylinder for a dump trailer?
My first dump trailer was power up but gravity down. On two occasions I was a little behind in my greasing of the scissor lift mechanism and I could not get the dump box to come down on its own. My second and current trailer is power up and power down which has always worked. Even the few times that I almost killed the dump battery dumping a heavy load there was always sufficient reserve power to bring the dump bed down. The Load Trail 16' dumper I am looking at comes standard with power up and down and for $150 extra I can also have gravity down. Do you see any advantage to purchasing the gravity down option?
I look forward to the TBN expertise in assisting me with finalizing this decision.
Regards,
Lauren
Regards,
Lauren
