bushhog height
   / bushhog height #1
chinawall
I am having trouble adjusting the height of my bush hog. It sometimes cuts or digs into the ground. Any suggestions?
   / bushhog height #2
If you don't have a manual, download one from Land Pride/Bush Hog/Woods etc. set up is pretty much the same on all. If you can't find one let me know and I will post some off mine.
   / bushhog height
Thanks, TR
   / bushhog height #5
   / bushhog height #6
Normally, you can set the cut height with a combination of the tail wheel and your rockshaft (3PH) lever stop. You'll want the aft end of the cutter a bit higher (an inch or three) then the front.
If your ground is uneven, the sides of the cutter will dig in occasionally...unless you want to constantly adjust that rock shaft lever. I doubt you can prevent digging in 100% of the time.
   / bushhog height #7
x2
How low are you trying to mow?
   / bushhog height #8
I too am having problems with a new "used" shredder I purchased recently. I had a Howse 6' shredder and it cut great, but it was a cheap one with thin steel and it rusted through in too many places to continue getting fixed and welded back together. I purchase a used Tractor Supply Co (TSC) brand shredder with taller sides than the Howse shredder. My problem with the TSC shredder is that on level ground, without digging trenches from the sides digging into the ground, the grass height is about 8" tall. I'd like it cut lower, such as 3" tall grass/weeds. Is there a way to safely lower the stump jumper disk so the blades get lowered, or are there blades made for this purpose that drop down lower to the ground than standard blades? I looked on the TSC web site and they only list 1 set of blades for a 6' shredder. I assume that's the same set that came with this used shredder I purchased.
   / bushhog height #9
My King Kutter shredder was the same way when I got it.
Could not cut low and the front of the cutter was always digging in.
I cut the front sides of the cutter up a couple inches and tapered them back about a foot.
Then welded on new skids where I cut.
Easy, cheap and the cutter works much, much better.
I can cut several inches lower without the front of the cutter constantly leaving trenches
   / bushhog height #10
Measure your blades. Length, width, thickness, and hole diameter.
Then just browse online for similar blades with more offset. Perhaps someone replaced your blades with ones that dont offset as much.
Pictures would also help.
When you set the cutter on level concrete pad, unhooked from the tractor, what is the height of the blades?
Also, 3" is too low for a rotary cutter, and borderline too low for even a finish mower.
2014 Ford F-150 4X4 Ext. Cab Pickup Truck (A53422)
2014 Ford F-150...
2019 CATERPILLAR D6T LGP HI-TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
2019 John Deere 410E 40 Ton Articulated Off-Road T/A Dump Truck (A55787)
2019 John Deere...
2016 Nissan Pathfinder SUV (A55758)
2016 Nissan...
2014 Jeep Patriot SUV (A53424)
2014 Jeep Patriot...
Gas Pump Artwork (A55758)
Gas Pump Artwork...
