Cost of a new dpf filter for an L60? Just curious.
   / Cost of a new dpf filter for an L60? Just curious. #1
BGigHarbor
Gold Member
GIg Harbor ish
.l5460, bcs 725, 852
I've read costs for car and light trucks dpfs run from like 2.5k to over 6k$.
Any dealers care to look up and share the cost of a replacement dpf for say a l5460?
Just curious.
Manual says cleaning or replacement at 3000h, and hopefully in the next few years the technology for cleaning them will continue to improve and get cheaper. And hopefully they really do last at least that long...
   / Cost of a new dpf filter for an L60? Just curious. #2
Do you need to fill up a dpf tank? Or is it just the filter?
To be honest I don't know what you meant to fill up a dpf tank unless you are talking some sort of urea injection (my ignorance).
I guess the bottom line question is how much would a dealer charge to replace the dpf filter in the event it couldn't be cleaned.
   / Cost of a new dpf filter for an L60? Just curious. #4
DPF Filter Kit (DPF) P/N: 1J804-18910 is $659.64 on Messick's web site.
Catalyst, Kit (DOC) P/N: 1J804-18910 is $1,729.60
How long is the emissions warranty on the new tractors? On automobiles the emission warranty is much longer than normal vehicle warranty as this is dictated by the federal government.
   / Cost of a new dpf filter for an L60? Just curious. #5
The emissions warranty on compression ignition engines over 50 HP is 5 years or 3,000 hours. Engines under 50 HP are warranted for 2 years or 2,000 hours. The emissions warranty covers everything in the fuel system, DPF system, EGR system, turbo, exhaust and intake manifolds, and the ECU system including sensors. The warranty is void if there is customer neglect like running high sulfur fuel, non-CJ-4 oil, and not replacing filters and lubricants per schedule.
   / Cost of a new dpf filter for an L60? Just curious. #6
Once it's past the warranty,I'd just remove it and figure out how to stop regens ..it's an off road tractor,no ones going to care,so many people are removing them on on highway vehicles,they create more problems than they solve.DPFs cause more engine failures than you can imagine,and poor mpg,if you suspect it's clogged get rid of it before it costs you an engine.
   / Cost of a new dpf filter for an L60? Just curious. #7
Just wondering for the uria that liquids you put in just for my own info I just hate all these dpf systems!!!
   / Cost of a new dpf filter for an L60? Just curious. #8
I don't think the tier 4 systems implemented by Kubota require DEF. I'm in the process of buying my new 4060 and the dealer assured me no DEF.
   / Cost of a new dpf filter for an L60? Just curious. #9
That's good that whole system is a pain in the ***
   / Cost of a new dpf filter for an L60? Just curious. #10
Kubota's system in the grand Ls do not use DEF!
Sterling 9500 (A56436)
TANK MANIFOLD (A58214)
2015 Peterbilt National NBT40 Crane Truck (A60460)
2015 Peterbilt...
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A58216)
2014 MAGNUM...
2007 Ford E350 (A55973)
2007 Ford E350...
*Selling at Royal Auction Zephyrhills, FL Location* (A59228)
*Selling at Royal...
