First Oil Change- what weight oil?
   / First Oil Change- what weight oil? #1
pizzaguy
Northwest IA
Kubota L3240 HSTC
Going to do the first service on my Grand L3240HSTC and I am planning in using Rotella oil. The tractor is used harder in the winter to run a snowblower than I use it in the summer. Temps range from -20F winter to 90+F in the summer. I am thinking 10W30 or 10W40 T5 Rotella would be good, but can't find 10W40 here. The other Rotella available is 15W40,which I don't think is good for winter. Is the 10W30 a good choice for these conditions or what would you recommend?
   / First Oil Change- what weight oil? #2
How many hours do you have? I ask because 15W40 is likely appropriate but synthetic would be a better choice as long as you have maybe 100 to 150 hours.
Right around 35 hours but I have had it about a year.
   / First Oil Change- what weight oil? #4
Rotella 10W30 would be a great choice for your usage if you don't need/want synthetic.Very popular in these parts for compact tractors.
10W30 is the factory fill on Kubota-many members use Rotella 10W30 as well.
Good Luck!
   / First Oil Change- what weight oil? #5
At 35 hours the 10W30 is the better idea.
   / First Oil Change- what weight oil? #6
Is it sitting outside for the -20 starts? If so synthetic 5W-40 although it is more expensive. In a heated garage the other oils will do.
   / First Oil Change- what weight oil? #7
Gonna go out on a limb here... What does the manual say to use? The factory manual for my old '41 Farmall A, '85 Kubota B8200, and current NH TC40D all spell that out pretty clearly.
   / First Oil Change- what weight oil? #8
Owners manual for oil viscosity/weight is very outdated. We have similar temperature conditions, and I would suggest a 5w-40. Here is an excellent viscosity chart from Caterpillar. Philip.
  • Cat oil recommendations.pdf
   / First Oil Change- what weight oil? #9
My VW TDI uses 5w30 synthetic ESP oil. Same oil (minus the ESP) is specified for my 1025 (and was for my 4010) JD. It's available locally at Advance Auto here as Castrol 5w30 for less than $15 for the gallon or 5 liter container. This is what I plan to use in my 1025. Can't get Mobil 1 for diesels here; it seems; otherwise, I'd use it.
A xxw30 is all you need for the winter and is fine for the summer as long as you're not working it hard in temps >90 F. I'd get the lower "xx" that you can find for a diesel. 10w30 is too middle of the road. Go to at least a 5w30.
Ralph
10W30- But as PHILIP8N stated, the manual is outdated on viscosity/weights and does not even mention synthetics or 5Wxx or 15Wxx oils.
2008 FREIGHTLINER B2 BUS CHASSIS (A52576)
2008 FREIGHTLINER...
Case IH 3408 8 Row Corn Head (A52349)
Case IH 3408 8 Row...
2015 INTERNATIONAL PROSTAR TANDEM AXLE MID ROOF SLEEPER (A52577)
2015 INTERNATIONAL...
2003 FONTAINE TL50-NGB TRI AXLE RGN TRAILER (A52576)
2003 FONTAINE...
2020 Mathieu MC210 Azura Flex Street Sweeper (A51691)
2020 Mathieu MC210...
2025 CFG 12EX-ATA Mini Excavator Attachments (A50325)
2025 CFG 12EX-ATA...
