BoonDoc
I was enjoying my new box blade with my 2012 Boomer 30, ripping the crown off the trail into my camp when one of the tines hit a big rock. I noticed the tine was bent to the side like it was made of plastic. I also noted the box blade freely swinging left and right. Aside from tearing off the pin that sets the length of the left stabilizer arm, the right arm was hanging loose. Seems the mounting point sheared off. On closer inspection, I see that the mounting point is not a large bolt coming through the frame but a pin that's welded on. Getting her to a welder or the shop is a haul, so I was wondering if I could find a spot, maybe an inch forward, and drill a hole for a large steel bolt to come through. I assume the frame isn't hardened steel and could be drilled by hand? Anybody seen this happen and is there a good fix?
Doc
			Doc
