Who knows why this happens
   / Who knows why this happens #1
Desert Bred
Goodyear AZ
1998 CKC TS 254 (Fei Dong 295T1)
When flicking a lighter (no gas applied)- little sparklets appear.
Who knows?
   / Who knows why this happens #2
Video not working, but probably just like holding a piece of steel on a grinding wheel. Little glowing bits of metal make the sparks. They can start a fire it they are hot enough and land on something flammable.
Bruce
Brilliant! And you didn't even see it.
   / Who knows why this happens #4
Uh... sparks off of a lighter? Really? Someone made a video of sparks coming off a sparker on a lighter? I want my 10 seconds back.... actually, 30 seconds. I watched it three times. :mur:
I'm missing something M-R.. just flicking the lighter in the direction of the fire sparkles. seriously.. i didn't know what it was but bcp gave a pretty good response.
   / Who knows why this happens #6
Flint.... In the lighter. It is what makes the spark. That lights the fuel. Is this new? Are we dealing with someone that doesn't understand fire?
The flint will make a spark even if the piece of flint is not a spark. When it hits a heated area it will look like a sparkler.
Experiment...... Heat a flint not in a lighter by holding it in pliars, then throw it against a hard surface. It's more than you would expect. No combustible near the area though for safety.
   / Who knows why this happens #7
Back in the late 70's I stared at a sparking lighter for hours. There was some synthetic help from Mr. Leary.
   / Who knows why this happens #8
It's really hard to tell what's going on from the video. I suppose everyone is familiar with the flint/steel sparking phenomenon; at least anyone who ever used a lighter should be. There is another phenomenon called a "flash point", the point where a substance will "flash" when heated and exposed to a flame. That could be part of the effect that you are seeing, i.e., the fuel in the fire could be giving off combustible gasses that are just at the right temperature to "flash", but not in sufficient quantities to sustain a flame.
   / Who knows why this happens #9
I'm old enough to remember Zippo lighters (the metal flip top ones that used lighter fluid). Every so often you'd have to replace the flint in the lighter. They look like 1/4" pencil lead. Sold in packs of 5.
The lighter's rough wheel heats the flint by friction and causes small pieces to fly off as sparks. Disposable lighters use the same process.
Yes there may be something else going on here. Sorry that the video doesn't capture it but next time you start a fire you have to try it.
Without depressing the gas just flick the lighter (from a few feet away) at the hot embers.
**away from the lighter and at the surface of the dust (or embers), a chain reaction of tiny stars light up bright white really quickly like firecrackers without sound.
I was thnking that the first response was a correct analysis of what is happening but the flint should be completely burned out by the time it were to hit the embers of the fire or maybe not. But check it out sometime I can't find out anything on the net about it.
2003 Lincoln LS (A50324)
2003 Lincoln LS...
UNUSED SWICT 84" QUICK ATTACH BUCKET (A54757)
UNUSED SWICT 84"...
2018 PRINOTH PANTHER T14R ROTATING CRAWLER DUMPER (A52705)
2018 PRINOTH...
2002 Ferguson SP915RE Ride-On Pneumatic Asphalt Compactor (A52377)
2002 Ferguson...
2017 Caterpillar D6T LGP Crawler Tractor Dozer (A53421)
2017 Caterpillar...
UNUSED RAYTREE RMA42 HYD AUGER (A54757)
UNUSED RAYTREE...
