Anyone else hate the new light bulbs?
   / Anyone else hate the new light bulbs?
dave1949--I just like it bright plus am red-green colorblind and that apparently makes it harder to see in lower light conditions. OK, I'm older as well...:D
If a bulb says it replaces a 60W bulb does that mean it produces the same amount of light as a 60W incandescent?
   / Anyone else hate the new light bulbs? #12
I've read that they are designed to work with the threads facing down. If you put them in the ceiling, or with the threads facing up, they overheat and burn out quickly. I'm not aware of any fire dangers from the heat, it's more along the lines of overheating the bulbs themselves.
I'm sticking with standard bulbs for as long as I can get them!!!
Eddie
   / Anyone else hate the new light bulbs? #13
Over the years I've replaced all the bulbs in the house with CFLs. Once they warm up the light seems OK and for sure they have lasted longer than standard incandescent. Outside, porch light, I finally found one CFL that has almost instant on features. Otherwise, outside, the CFL is a slow starter especially in the winter.
As I've aged, gracefully, I need either more light or my reading glasses also.
   / Anyone else hate the new light bulbs? #14
That's the claim as I understand it. I think the color of the light will make a difference in our perception of how useful it is, and not everyone likes the same light color.
   / Anyone else hate the new light bulbs? #15
Think they've lost some quality in making the convoluted designs. They likely lose their gas and go bad due to leakage. Now, LED ones are out that use less energy yet. They won't be prone to the leakage of the CFLs. I never had any problem with CFLs being as bright. Some of them are slow to warm up and get bright. Newer ones don't seem to have this problem. The LEDs are fine, but expensive.
Ralph
   / Anyone else hate the new light bulbs? #16
I was at Costco the other day looking for some CFL's to replace incandescent bulbs that had burned out in the kitchen. They had a light bar with the various LED's in it and you could plug it in an check them out. They come on pretty instantly and to me the light looked the same as an incandescent. However, at $18 per bulb I passed. They had a CFL 4 pack normally $11 with an 8$ instant rebate from the power company. For less than a dollar a CFL I bought a couple packs and don't really care if they burn out sooner than what they are supposed to. Local recycling place takes CFL's so proper disposal is not much of an issue.
I would like to use CFL's on my wrap around porch but they just don't function well in the winter which is the primary time of year we have the porch lights on. My wife loves to turn them on and leave them on for hours on end with no purpose. :confused2:
Oh, and I do like the slow start of CFL's in some places... like the overhead lights in the bathroom. The warm-up gives your eyes time to adjust on those dark winter mornings ;)
   / Anyone else hate the new light bulbs? #17
I put LEDs in the kitchen ceiling can lights and they burned out. There is a power supply in the base of the bulb that burned up. I now have CFLs in there but they aren't compatible with the dimmer switch and won't dim so they have to come out. The switch "hums" when ever the slider is moved off minimum. Going to try to find the old type and buy a supply of 'em.
   / Anyone else hate the new light bulbs? #18
My wife loves to turn them on and leave them on for hours on end with no purpose. ...........I heard years ago that it takes as much power to start a CFL as it uses in 8 hours so it's cheaper to let it burn for 8 hours than it is to turn it off and on ....that was several years ago ....things may have changed in that regard.
   / Anyone else hate the new light bulbs? #19
We have been using CFLs for about 10 years now. We have something like 85 can lights in the house and there was no way I would pay the power bill for regular light bulbs AND have to deal with their short lifespans. As it is, even with CFLs, I had to replace a few bulbs every couple of months. Not a big deal, but since we have 10 foot tall ceilings, I have to get out the ladder.
There are good CFLs and crappy ones. The originals CFLs we bought from HD were excellent and lasted for the rated lifetime. We still have many of them in service in low usage fixtures both inside and outside the house. We used to buy CFLs from Lowes that were just crap. They would last a very short period of time before failure. As a result of the failures, I now right down the install date of the bulb. I returned a few of the Lowes CFLs thinking I just got a bad one or two but it became obvious that the Lowes CFLs were crap. I know only buy named brand CFLs like GE and we have not had anymore problems.
Most of our CFLs are R30s and R40s but I am slowly replacing these with plain old CFLs due to cost.
There are different wattage CFLs just as there are for the old bulbs. When I designed the house, I used more light cans that needed so we would have plenty of light even with low wattage bulbs or bulbs that had gone out. I think we are using 60 watt equivalent bulbs at this point and they work well for us. We have some task lighting FL tubes in the kitchen that have been running since we built the house. The only time the bulbs have been off is when we had family visiting who turned off the lights or during power outages. Of the eight bulbs, only two have been replaced in almost 10 years of use.
I like the slow start up on the CFLs. I don't like the shock of the light first thing in the morning so the slow warm up works for us. There are supposed to be instant on CFLs.
Later,
Dan
   / Anyone else hate the new light bulbs? #20
CFL brightness, time to light and longevity vary greatly with brand and cost.
The Sylvania bulk box CFL's I have in all my fixtures other then the pots in the kitchen come on very fast and have been in use for over 3 years now. I shouldnt say all, I did loose one of two in my bathroom exhaust fan, but I consider that extreme service, what with the steam and vibration, so its not unexpected.
Until I got these Sylvnias, I was buning out the cheap chinese ones fairly regularly. I also dont like Philips CFLs either.
Now the Philips LEDs with the yellow lenses are darn near the best bulbs Ive ever seen. I got 2 of those and one older Philips LED on dusk to dawn outside with no issues. The oldest one was 1st or 2nd generation, close to 5 years old now, still no issues. When on promotion, you can find the "yellow" Philips for $15 or so, money well spent!
LED is the future. CFL will be around for a bit, but I fully suspect it to be gone in 10 years.
FENCE PANELS (A58214)
1996 Dorsey Enclosed Trailer, VIN # 1DTV11520TA252324 (A57453)
1996 Dorsey...
2019 KOMATSU D61PXI-24 CRAWLER DOZER (A60429)
2019 KOMATSU...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
2025 Swict 84in Bucket Skid Steer Attachment (A59228)
2025 Swict 84in...
2019 Dodge Grand Caravan Van (A59231)
2019 Dodge Grand...
