Tachometer problems in cold weather
   / Tachometer problems in cold weather #1
DJRussell
Member
Calgary, Canada
Massey GC2610
Hello all.
I have a GC 2610, approximately 450 hours. Have owned it since Spring 2013. Tachometer worked flawlessly in the spring and summer months. First cold day this fall, it acted up and the rpm's indicated over 3000, even when barely above an idle. Shut it down, and it worked fine. That was with the temperature about 45 F. Today the rpm's indicate over 3000, actually the needle was buried, and made a whirring sound.
Has anybody out there had this problem, and how did you solve it?
If I have to, I would be willing to disconnect the Tachomter for the winter, to save it for the summer when I really need to monitor the rpm.
Problem is, I don't really know how to disconnect the tach.
Any help would be appreciated.
Regards
Jim
Apologies to all. I have now searched the forum and saw a thread by rjmack, describing exactly the same symptoms. I will simply cover the vent holes in the hood, and if no joy, then disconnect the cable for the winter. I don't want to destroy the tach. Don't really need it for pushing snow, but sure need it for mowing and backhoe work.
Regards
Jim
   / Tachometer problems in cold weather #3
Yes mine was doing the same thing last year. I covered the vents on the hood above the thach and it has not done it since .Many on here have mentioned the same problem .
   / Tachometer problems in cold weather #5
Regards
Jim
I tried covering the holes, doesn't really do much. the problem still exists and I am wondering how long it will be before the spinning end of the disconnected cable wears a hole through something important in the dash.
massey ferguson obviously doesn't give a hoot about their name anymore. if there are any lawyers in the crowd, I would be happy to sign up for class action.
Oil the cable.:
you obviously don't own one of these.:(
   / Tachometer problems in cold weather #6
No I don't.
Long time ago when vehicles had speedometer cables they used to act up as described. Oil did work for them.
   / Tachometer problems in cold weather #7
No I don't.
Graphite would be much better than oil on a spedo or tach cable.
There is a design defect here, and lubrication has been tried.
   / Tachometer problems in cold weather #8
No I don't.
this is the problem.
Massey Ferguson Tachometer problem - YouTube
you can see in the video that I have the vent cage stuffed with plastic grocery bags to try minimize the cold air across the tach. I just thought today of taking the radiator screen out and putting a piece of cardboard or plastic in there and try that.
This problem does not occur in warm weather, but it was barely below freezing when I took this video, when it gets cold you can hardly bring the rpm's up at all.
   / Tachometer problems in cold weather #9
Still glad mine doesn't have a tach. :thumbsup:
   / Tachometer problems in cold weather #10
Finally switched computers and watched the video.
Sound just like the old speedometer cables and acts about the same but with much less swinging.
Suggestion if possible: run tube back from front of engine and use a 12 volt computer fan to blow on the tack????:confused::confused:
More info coming soon! (A55851)
More info coming...
2013 Ford Taurus AWD Sedan (A55853)
2013 Ford Taurus...
UNUSED FUTURE 16" HYD AUGER (A52706)
UNUSED FUTURE 16"...
2018 Ford Explorer AWD SUV (A55853)
2018 Ford Explorer...
2021 Chevrolet Tahoe SUV (A55853)
2021 Chevrolet...
Service Truck Hydraulic Rear Liftgate (A55787)
Service Truck...
