2013 Tundra oil change interval
   / 2013 Tundra oil change interval #1
deerefan
louisiana
1952 8N, 2005 JD 5103
I called the dealer today as we are nearing the 5k mile mark to schedule the 1st oil change. Since it has 24mo/24k mile free maintenance, I figured I would take advantage of it. The service writer told me I am only due for a tire rotate, oil change intervals are 10k miles and 5k on severe duty schedule. This is also in the manual. I am wondering if this interval increased when they offered the free maint program. The truck, per the svc writer, has 0-20w synthetic, allowing for the 10k mile change interval. Hmmmm....thoughts?
   / 2013 Tundra oil change interval #2
My GMC goes apx 6-7k before the computer yaps for an oil change which I believe assumes dino, not synthetic...I'd say it sounds reasonable given the synthetic.
Guys that I work with that have expensive European cars that are all synthetic are going around 10k per the manuals and computers.
   / 2013 Tundra oil change interval #3
If, and I say if, if you sleep ok at night with 10,000 miles oil changes, then, I say, by all means, stay at 10,000 mile oil changes.
   / 2013 Tundra oil change interval #4
My 2006 tundra is every 7k with a sythetic blend. If you really want to be shocked our service intrivals for some of our semi trucks is 50K (DD15 engines)
   / 2013 Tundra oil change interval #5
I have a 2011 Tundra with the service package but I change my own oil even though the dealer would do it for free. Me decision was based on the complex oil filter arrangement ant the numerous complaints of dealers screwing it up or overtorquing the canister and causing oil loss and engine problems. I want no part of that.
Search the net or check TundraSolutions website. it's a little hairy to change the first time but the second time is a breeze. I change my oil--synthetic--at 7,500 or so miles and use 5W20. That viscosity is what it came from the factory with so it's good enough for me. A lot of guys say the 0W20 causes too much engine noise. I took their word for it.
   / 2013 Tundra oil change interval #6
I've got a 2013 and I DIY mine, skipped the dealer freebies. I want to go twist their arm to give me a half dozen filters in exchange for not taking them up on that.
I also changed out the plastic filter cap with an OE aluminum one. You can get them off Ebay complete with an aluminum wrench.
   / 2013 Tundra oil change interval #7
My 2007 Tundra 5.7 came with regular oil and I based the oil changes on 5,000 miles. At 48,000 miles I switched to synthetic oil and now use the 10,000 mile interval.
   / 2013 Tundra oil change interval #9
If it were MY new truck and I planned on keeping it for 100K or longer I would change the oil at 5,000 and 15,000 miles on my dime, and let them do it at 10,000 along with their tire rotation. This is what I'm doing with our new Carry. After they do it at 15K then I'll change the oil every 7,500 miles (Mobil 1) which is about once per year for us on both the Camry and my old Tundra.
   / 2013 Tundra oil change interval #10
Dusty--I've been searching but can't seem to find one. what do I search for?
2007 Amkus Rescue System (A53421)
2007 Amkus Rescue...
2017 Jeep Patriot 4x4 SUV (A53424)
2017 Jeep Patriot...
2012 PETERBILT 337 CHEMICAL TREATER TRUCK (A55745)
2012 PETERBILT 337...
2018 PINSA 130BBL VACUUM TRAILER (A53843)
2018 PINSA 130BBL...
(NEW) 2025 DOWN 2 EARTH GOOSENECK TRAILER (A51247)
(NEW) 2025 DOWN 2...
2016 Ford F-450 12ft Flatbed Truck (A55852)
2016 Ford F-450...
