Southern English
   / Southern English #311
I grew up in SC hearing the term "Foot Feed".
These youngsters don't remember when the dimmer switch was on the floor. The last one I had was 91 Ford F-150
Sent from my iPhone using TractorByNet
   / Southern English #312
My old memory is slipping. I had so many with the dimmer switch on the floor, upper left side, of course, that I'm not sure anymore which ones; maybe my '89 F250 was the last one. And how many remember (or even knew of) cars with manual transmissions that had the starter switch under the clutch pedal; just turn the key on, press the clutch all the way to the floor and that engaged the starter.
   / Southern English #313
Or you turned the key on, then pushed a button to activate the starter.
I drove something with a manually engaged starter with a pedal on top of the transmission hump. Push on the pedal to engage the gears, then a little more to operate the electrical switch. Can't remember what it was.
Bruce
   / Southern English #314
And just the opposite. On my 1962 Austin Healey Sprite, you turned pm the key, then pulled a knob on the dash to engage the starter.
   / Southern English #315
Dimmer switch on the floor was a twit of a thing in salt country. The switch and internals would be rotten with corrosion .
   / Southern English #316
Help me remember. I learned to drive in my Dad's 1953 Chevrolet pickup. Was there a starter button (switch) on the floorboard?
Am I correct in remembering that it had a manual choke knob on the dash?
Steve
   / Southern English #317
Dimmer switches on the floor was a pretty standard thing. But then my 1955 Cadillac Coupe de Ville had an automatic dimmer switch; an electric eye (I guess you'd call it) mounted on top of the left end of the dash. The lights from oncoming traffic would cause my headlight to change to low beam, and it you wanted them on high beam anyway, you could just put you hand over that thing to shut out light from getting to it, and the headlights changed back to high beam.
   / Southern English #318
Steve
Steve, I don't recall the Chevy pickups having a starter button on the floor, but I do think you had the manual choke knob on the dash.
   / Southern English #319
Yep 53 chevy pickup had a foot starter switch
   / Southern English #320
I seem to remember a foot starter on a '55' Willys PU I had...seems the foot button was actually part of the starter itself?
2002 JOHN DEERE 450H CRAWLER DOZER (A51406)
2002 JOHN DEERE...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A51692)
2013 Ford F-150...
2015 Infiniti QX60 SUV (A51694)
2015 Infiniti QX60...
UNUSED TOPCAT SSSCR72-72" HYD SOIL CONDITIONER (A51248)
UNUSED TOPCAT...
UNUSED RYOBI 80V HP BRUSHLESS ELECTRIC PUSH MOWER (A51248)
UNUSED RYOBI 80V...
2016 CATERPILLAR D6K2 LGP CRAWLER DOZER (A51246)
2016 CATERPILLAR...
