Oil & Fuel Oil Bath Filter
   / Oil Bath Filter #1
Travis_R
Livingston Parish, LA
Yanmar YM2500
My MF231 has an oil bath filtration system for the air cleaner. I cleaned the oil cup and all the wire mesh this evening.
Ok, so the oil cup has 2 parts to it. Inner and outer cups... My question is should I fill up only the outer part of the oil cup, or both the outer and inner parts of the cup? The inner cup has 6 tiny holes all the way around it. I'm getting different opinions on this question from research.
Thanks
   / Oil Bath Filter #2
Fill it as the owners manual states. Cheaper than buying a new engine.
   / Oil Bath Filter
I completely agree. But my tractor is second hand and the pages are torn out of the original owner's manual that came with the tractor.
   / Oil Bath Filter #4
Are there oil fill marks on the cleaner? There was on my Ford.
   / Oil Bath Filter
Yes there is an "exact oil level" marking on the outside of the oil cup... But should I also fill the inner cup to that line too? If I fill the inner cup up with oil, the oil will be right below the 6 tiny holes that go around the inner cup.
   / Oil Bath Filter #6
I believe that line is just for the outer.
   / Oil Bath Filter #7
Fill up both parts to the oil fill line. Put the same weight of oil into it as what you put into engine.
   / Oil Bath Filter
How sure are you on this? I can't afford to ruin my engine. I just want to be sure.
Thank You
   / Oil Bath Filter #9
So that line IS for both sides? I had a oil bath in a ford truck never a tractor.
   / Oil Bath Filter #10
Iam postive. Have ran and still run tractors with oil bath air cleaner. Also have one on my old 3 ton grain truck. If anything your more likely to hurt the engine with too little oil than too much.
1992 Ford F-150 Pickup Truck, VIN # 1FTDF15Y3NNB06697 (A51572)
1992 Ford F-150...
2004 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A55745)
2004 INTERNATIONAL...
2012 BOBCAT E80 EXCAVATOR (A52707)
2012 BOBCAT E80...
2010 Turfco Mete-R-Matic III Pull-Behind Top Dresser (A55851)
2010 Turfco...
2005 Nissan Frontier Crew Cab Pickup Truck (A55852)
2005 Nissan...
2008 Dodge Avenger Sedan (A53424)
2008 Dodge Avenger...
