Diesel fuel treatment
   / Diesel fuel treatment #1
Rohdog
Clyde, Ohio
1978 D6806 Deutz,1966 MF 135
Anyone ever try seafoam in diesel fuel tractor? Do you put it in fuel filter or just add to tank?
   / Diesel fuel treatment #3
Skip the seafoam and go straight to Howes.
Thank you, I' getting tired of this snow and cold..here in northern ohio...i'm sure it's the same in Wisconsin. Giving my tractor a workout this winter..for sure.
What is Howes?...better than seafoam?...add to fuel or add to fuel filter when new? I have power service in fuel now but I want something to clean fuel system.
   / Diesel fuel treatment #6
Seafoam, also known as snake oil. Is only IPA, naphtha gasoline and baby oil/mineral oil.
Save your money and run #1 dewaxed diesel in the winter. Dose it with a little IPA to absorb the water.
I do run off road diesel...with power service.....maybe i'll just leave it be.
   / Diesel fuel treatment #8
seafoam is not worth the money for regular use! I used to use it but it cost 4 times as much as Lucas fuel additive. For gasoline I only add ISO heat alcohol fall and spring. I change my filters and the fuel additives are not worth the money.
For diesel only add a winter anti gel. Can't trust the pump around here. Howes an power service are great anti gel around here!
   / Diesel fuel treatment #10
I used to use Power Service white bottle, until they changed the formula and instructions. They now warn to only use it in cold months. I switched to Howes Diesel Treat, which can be found just as easily, and it can be used year round. No gel problems.
Maker-Bot Replicator 3D Printer (A51695)
Maker-Bot...
2018 KENWORTH T880 DAYCAB (A53843)
2018 KENWORTH T880...
UNUSED CFG INDUSTRIAL MX15RX EXCAVATOR (A52706)
UNUSED CFG...
2003 John Deere 310SG (A47477)
2003 John Deere...
Misc Qty 5 Microwaves (A51695)
Misc Qty 5...
Toaster Oven (A51695)
