wrangler6831
- Joined
- Dec 1, 2004
- Messages
- 236
- Location
- WV
- Tractor
- 2- 65 M-F, 6245 Zetor /loader, GC2600 M-F /loader, BX24 Loader/BH
Tankless water heaters aren't set it and for get it. They require a fair amount of maintenance . I don't care how much you filter your water, When water is heated all the minerals will separate out of the water and end up stopping up the water passages in the water coil ..If you perform the required maintenance you should be ok. Other than maintenance, there are a fair amount of electronics. When these parts fail it's expensive to repair. Tank type water heaters are more forgiving when it comes to maintenance .. They can be said to set them and forget them, & they have less parts to fail.... As a contractor, I can purchase and install any water heater I want... For me it's the tried and true tank type water heater NG, Propane or electric. Their pretty much maintenance free and if a part fails it won't wont cost you an arm and a leg...
I'm not sure what experience you have but I have done ZERO upkeep on either of mine in the ten years I have had them. This includes about 8 years on well water (no filter or conditioner) and the last two years on city.
P.S.
After searching youtube I did find a video showing to flush with vinager once a year, but I'm about ten years behind and they still work like new.
