310-B John Deere steering housing
   / 310-B John Deere steering housing #1
gammer
Nova Scotia
Ford 4500 tlb
Hello All! Itç—´ a long time sense I been here on line, life on the road working all over.
My next door neighbor has a 1972 310-B John Deere, The steering housing cracked so the hyd fluid leaks out, and he is trying to locate with no luck a replacement. He had 2 shipped in but it turned out to be the wrong part. i was hoping someone in here with such a large network would know where to locate one.
The part number is T-82325
Thank you all in advance for your help!
Itç—´ very much appreciated
   / 310-B John Deere steering housing #2
T82325 isn't a valid part number. This is the steering valve for a 310B AT176926 Flow Control Hyd. Valve ADD 1,457.17 USD
Hi Jim,
This is the info they gave me, he told me they had 2 shipped up but they were different, I will diffidently pass this info on to them. This is probably the reason why they were different.
Thank you for this important info.
   / 310-B John Deere steering housing #4
Since I think JD outsources the steering valve I think the housing will not have a JD casting number.
wow didn't know that Jim,
I should have done my homework myself instead of listening.
Jim,
Is there a difference in this part between Canada and the US, that you know of.
I'm trying to figure out how they got it mixed up twice, not once twice.
scratching my head.
Thanks again Jim for you help.
   / 310-B John Deere steering housing #7
JD lists only one parts catalog & only one PS valve for a 310 B. Are you sure the machine is a 310 B?
   / 310-B John Deere steering housing #8
Jim correct me if I am wrong, A few weeks back we had a JD 410 backhoe in our shop front tag on frame said 410-B yet it was straight 410. I believe it was in the parts manual that I read the B stands for diesel engine? sent the manual with the tractor when customer picked it up so I can't check. Would they have been building the B series in 72?
Jim,
I located a part for the tractor, I used the part number (Sub AT101661) I got from John Deere. that was the only number showing for that part, I don't know what the "Sub" stands for.
Thanks for the info Goaliedavid, I will verify, I'll need to look for the info on the machine, make sure it is what they say.
Ford F250 Pickup Truck (A51694)
Ford F250 Pickup...
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A53472)
Kubota SVL65-2...
UNUSED RAYTREE RMBD72S-72' DRUM MULCHER (A51248)
UNUSED RAYTREE...
2005 TerraGator 8104 (A53472)
2005 TerraGator...
WB Mower (A50120)
WB Mower (A50120)
