Buying Advice Buying Finishing Mower
   / Buying Finishing Mower #1
Ken1234
Fairhope, al
Bobcat ct230
Am trying to find a GOOD finish mower brand. After looking around on the web this past week I keep coming up with the following brands as good mowers
  1. BEFCO
  2. Bush Hog
  3. Frontier (BEFCO)
  4. King Cutter
  5. LandPride
  6. Woods
Others that I have seen on various "To Sell" sites are
  1. Big Bee
  2. John Deer
  3. Rhino
What recommendations would anybody have out there as to GOOD finish mowers. Be using a BobCat 30hp three point hitch to pull it. Have about 4-4.5 acres (pecan orchard), not completely smooth but pretty close to smooth. The grass is not thick.
THANKS for any advice - Ken
   / Buying Finishing Mower #2
I was shopping for a 6' RFM last year. I started a thread like this one, asking advise. Woods and LandPride were the most recommended, but I ended up buying the Countyline brand from TSC. I got such a good deal I couldn't walk away from it. Since then I have picked up a used 4' Woods RFM. The Countyline does get the job done, {I mow 6 1/2 acres} but the Woods is the better mower.
Here is my thread if you think it will help you: http://www.tractorbynet.com/forums/buying-pricing-comparisons/285903-600-difference-between-land-pride.html
Larro
   / Buying Finishing Mower #3
  1. BEFCO
  2. Bush Hog
  3. Frontier (BEFCO)
  4. King Cutter
  5. LandPride
  6. Woods
  1. Big Bee
  2. John Deer
  3. Rhino
I bought a used (6ft.)woods model RD7200(rear discharge)Stout,very nice cutting mower.I found mine in excellent condition on craigs list for $1200 bucks about 3 years ago.I would go with the hard wheels or foamed filled tires.
   / Buying Finishing Mower #4
I've had BEFCO mowers...two of them ( 60" and 84" units). Both were great and long lasting. I traded the 60" RFM when I traded up to my 4400...which came with the 84" mower. The only reasons I sold the 84" mower was it was too wide for my garage door and larger mowers span uneven ground. If my lawn had been flat, I reckon I'd still have it. Both BEFCOs were trouble free and I do recommend BEFCO as a lower priced alternative to Woods and Land Pride. Do go with the hard tires...the inflatable types do lose air now and then.
I currently have a 72" Frontier RFM....Frontiers are manufactured by BEFCO and Woods, BTW..just painted green. Mine is Woods manufactured and it's great.
So, Woods or BEFCO....both trouble free units and well manufactured.
As far as width...I'd go as wide as you can if your tractor can handle the mower (power and weight) and you have a big enough place to store it (unless you plan on leaving it outside). 30 HP can easily handle up to 84", if that's PTO HP. Also, it's got to get between those trees, so consider that.
   / Buying Finishing Mower #5
We have a rearmount 90 inch woods at are gunclub, finishmower. You just can't beat them.
   / Buying Finishing Mower #6
I just got a LandPride 84" because many people rave about them and it works quite well. I need to paint it green yet.
My lawn is about 7-8 acres, mostly flattish but with small dips and hollows. If the wheels fall in a small gully the lawn will get a scalping. I don't have a lot of trees.
The 3 pt. in my opinion is suited for large treeless lawns, although getting used to the operation will allow me to get closer to trees without knocking them over. The first time out I scalped the crap out of the lawn until I adjusted the cutting depth up to 3-1/2 to 4 inches. It works nice now.
I don't regret the purchase yet. I considered a 90" but for me the price hike was to much to justify the 6" extra. Although they are more stout I believe.
   / Buying Finishing Mower #7
I'd check out Kioti finish mowers also. I don't know much about them, but they looked pretty heavy duty when I looked at them at the Kioti dealer near me.
   / Buying Finishing Mower #8
Sitrex is the OEM for the Rhino mowers, and I really like mine (90"). I picked it up lightly used at a spring equipment auction last year for $1k. Caroni is another good brand to consider.
I am going to change it to solid tires, but that's about it other than touching up a few paint chips.
   / Buying Finishing Mower #10
I bought a used 7 ft Land Pride finish mower that needed new tires, belt and blades for $600 a couple of years ago with side discharge and a slip clutch. I changed out the inflatable tires to solid ones after trying to patch and fix the original tires a few times. I would only get solid tires. The slip clutch is nice when you hit something. I have Gator blades on it now and they work good, but I just tried Fusion blades on my zero turn and now that's what I want to put on my finish mower.
I have a 35 hp 4x4 Century tractor that is a little light for it, but it gets the job done. When I lift it with the 3pt, you can feel the front tires coming off the ground and I have foamed tires with weights added to the front, but no loader.
For just mowing, it has plenty of power and can cut grass a foot long and longer, but I do have to slow down quite a bit.
Kubota sells Land Pride and they are very good at getting parts.
Eddie
2019 CATERPILLAR 299D2 XHP SKID STEER (A51246)
2019 CATERPILLAR...
2018 E-Z Beever M12R Towable Brush Chipper (A51691)
2018 E-Z Beever...
2017 Chevrolet Malibu 1LT Sedan (A51694)
2017 Chevrolet...
2008 Jordair Marines-320-DH Trailer Mounted Air Compressor (A51691)
2008 Jordair...
2025 New/Unused LandHero 16in Concrete Cutter (A51573)
2025 New/Unused...
Intermodel Metal Storage Crate (A51573)
Intermodel Metal...
