too much oil problems?
   / too much oil problems? #1
fluffhead31
Colchester, Vt
NH TC35A w/ 16LA FEL
I changed the oil and filter on my NH35A, and overfilled. It's well over the full line on the dipstick. What should i do:
a) Ignore it
b) Run it w/ the dipstick out and let some oil spill out.
c) remove plug and drain some.
Thanks!
   / too much oil problems? #2
Drain out the excess...
Too much oil can cause foaming (air in the oil) which results in poor lubrication.
Better a quart low then a quart high...
   / too much oil problems? #3
yup... loosen drain plug and drain some out.
   / too much oil problems? #5
an 8$ fix plus a car ride to solve a 1 minute with a wrench and bucket problem? um.. ok.... ???
   / too much oil problems? #6
$8 plus a trip to HF and the problem ISN"T solved. 1/2" ID tube won't fit down a TC35 dipstick tube. OP is out $8, wasted trip, has a useless transfer pump, and still needs to bend over and drain some oil out the old fashioned way.
   / too much oil problems? #7
even better!
   / too much oil problems? #8
I would take off the oil filter and drain it. Reinstall, start, then shut down and check. If needed repeat. Most filters will hold about 1/3 of a qt and this will be the less messy way of solving this issue.
Chris
   / too much oil problems? #9
Chris
Filter is mounted horizontally and holds maybe 3 ounces of oil. Makes a giant mess when removed. I spent 15 years servicing these tractors. Pull a drainplug. There really isn't a better way.
   / too much oil problems? #10
He could use the pump for his auto tranny fluid in his truck. In the past, prior to syn fluid fills, I'd suck out (through the dipstick tube) and replace a quart of auto tranny fluid every time I changed the engine oil. Did it do me any good? Guess so. Never had a bad tranny and didn't have to mess with the periodic drop the pan sloppy mess.
Mark
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
2019 Allmand Night-Lite V-Series 7kW S/A Towable Light Tower (A52377)
2019 Allmand...
Brock 5 Ton Feed/Grain Tank (A55218)
Brock 5 Ton...
2019 Max XD 20FT T/A Flatbed Utility Trailer (A52377)
2019 Max XD 20FT...
UNUSED IRANCH IRGC40 HIGH END MINI GOLFCART (A54757)
UNUSED IRANCH...
2019 Allmand Bros Maxi-Lite II 15kW S/A Towable Light Tower (A52377)
2019 Allmand Bros...
