Heavy duty Howse Bush Hog broke a blade at the bolt hole.
   / Heavy duty Howse Bush Hog broke a blade at the bolt hole. #1
Bspring
Member
SC
Heavy duty Howse Bush Hog broke a blade at the bolt hole. How common is this? I even have a clutch on the shaft. I was cutting some saplings in the woods and had run over some Poplar limbs about 2" in diameter when it came off.
   / Heavy duty Howse Bush Hog broke a blade at the bolt hole. #2
Uncommon for hog blades to break.. but not unheard of. since the bolt hole area is the are of least dimension.. it's a good place for damage to occur.
It's always a good practice to inspect blades when you sharpen /dress them.
if you remove them, i reccomend new shoulder bolts and never reuse the nuts, and never weld on the blades IMHO.
Inspecting the blades ability to freely move on the shouldered bolts.. but not too much slop, and a good rigid connection from the blade carrier bar or stump jumper to the hub.
Hope nothing was damaged / nobody hurt when it let go. Sometimes you can do everything correct and stuff just happens.
   / Heavy duty Howse Bush Hog broke a blade at the bolt hole. #3
I bush hogged many acres (over 100) a year for 20 years and never broke one, bent one though. I would look for a good quality replacement and replace them both unless they weigh the same. I wish you were closer, I am a blacksmith and would love to have the old one for the steel.
   / Heavy duty Howse Bush Hog broke a blade at the bolt hole. #4
I've broken three standard issue blades while brush hogging for customers. You never know what they have laying around that they "don't know about." :rolleyes:
I switched to heavy duty blades from my NH dealer. It takes longer for the tip speed to get up, but in the last four years I haven't broken one.
   / Heavy duty Howse Bush Hog broke a blade at the bolt hole. #5
They key is to buy hogs with blades that are 4" wide by 1/2" thick. You can brake those too but it's hard. They weigh more which also helps to cut through heavy stuff.
   / Heavy duty Howse Bush Hog broke a blade at the bolt hole. #6
I broke a blade when I lifted up to go over a stump but dropped the cutter too early and it came down at full speed on top of the stump. That's the only one I've broken. I don't blame the equipment.
Just an FYI, "Howse Bush Hog" isn't possible. Bush Hog (especially when capitalized as two words) is a brand name like Chevrolet. I'm assume it was a Howse brush cutter (rotary cutter, bushhog)?
   / Heavy duty Howse Bush Hog broke a blade at the bolt hole. #7
Howse calls them "rotary cutters."
Rotary Cutters - Product Lines
Long ago, after owning several CJ Jeeps, I bought a Toyota Land Cruiser. Everyone wanted to call it a Toyota Jeep.
Bruce
   / Heavy duty Howse Bush Hog broke a blade at the bolt hole. #9
i knew there was gonna be someone on here doing the PC bush hog / brush hog thing. .. yawn....
   / Heavy duty Howse Bush Hog broke a blade at the bolt hole. #10
Blade breakage depends on what you hit. I break blades on my brush bull 600 every couple years. It cuts saplings in the 1-3" range normally plus hits stumps and we have sooooooo many hard rocks lurking. And every year the frost brings up new ones to be hit. And these are the 4" wide by 1/2" thick blades. They snap at the bend transition, not the hole.
Blades break, that's why it's important to keep people away while cutting.
2021 BOBCAT T450 SKID STEER (A51246)
2021 BOBCAT T450...
JOHN DEERE RC7 R LOT NUMBER 224 (A53084)
JOHN DEERE RC7 R...
(4) Sumitomo 11.00 R22 Tires (A51573)
(4) Sumitomo 11.00...
2006 HAMM HD120HV SMOOTH DOUBLE DRUM ROLLER (A51246)
2006 HAMM HD120HV...
JOHN DEERE 54D LOT NUMBER 162 (A53084)
JOHN DEERE 54D LOT...
City of Buckhannon Onan 200 Set Stand By Generator (A52384)
City of Buckhannon...
