New Tractor Owner - Pics
   / New Tractor Owner - Pics #1
RichardDLee
Nottinghamshire, UK
Yanmar 3110D
Tractor came today, very excited to finally get it.
It is a Yanmar 1610D with a VTek 1A loader and a Beaconsfield transport box to lug things around and it helps balance it out.
After everyone having a drive and the kids being driven around in it I finally got to have a practice with the loader, got better the more I did it so I am sure once I have done some real work in it, it will become more natural.
I am going to be getting a plough and a rototiller/rotovator soon as well, help keep the veg growing area in good nick without the need of hard physical labour! I am also thinking about some forks so that I can palletise things and move them around easily, stone, sand, cement, blocks etc.
I have noticed that at one of the hydraulic junctions there is a slight leak, I have tightened it up and it has slowed but how tight can I tighten it? Can it be overtightened?
   / New Tractor Owner - Pics #2
Nice looking tractor. And the driver. :thumbsup: Is it a pipe thread leaking or gasketed. If pipe thread you might want to remove it and either put pipe sealant on it or teflon tape. I prefer pipe sealant and I have used a bunch on teflon tape. If it is gasketed you might want to remove it and inspect the gasket.
   / New Tractor Owner - Pics #3
Glad it arrived OK. It looks great. I'm a little jealous that it looks so good, mine's a real shed in comparison. I need to buy some tins of paint ASAP. With the loader and forthcoming attachments it's going to be a really useful workhorse no doubt.
   / New Tractor Owner - Pics #4
Hey.....that's great!!! Congrats on the tractor. I have a 186D.....pretty similar.....sure has come in handy. Keep that bucket low to the ground......add some weight in the rear with a full bucket or if you get those forks. Enjoy and be safe!!:thumbsup:
Thanks everyone..
Winston1 - er not sure..... it is a 19mm nut with a washer underneath that is attached to the hydraulic ram. I will get a photo if that doesn't make sense to you.
Bluest - thanks, it looks good for such an old tractor, James from the place I told you about delivered it, took the time to show me everything from how to drive it correctly to where everything was for maintenance. He and his mechanic have done a good job on it. It looks the part, I am glad I waited and got a FEL rather than having a hydraulic transport box which was my initial idea. Changed my mind when I realised I would be driving backwards turned the wrong way all the time.
jerrybob - thanks, yes they are very similar tractors. The transport box weighs 130kg ish, I weigh 100kg ish ;-) and I havent got the hang of getting the bucket good an full yet! The bucket up was just for photos, I have been warned about driving with it up, don't fancy a tractor on top of me to be honest.
Time to crack on and get it used this weekend. Can not wait. Oh I have a trailer for it too, it cost £10 and is currently undergoing refurbishment by my Dad and then will be a useful load hauling tool as well.
Has anyone ever reinforced the back of a transport box and put a towball through it? Either the part that slides out or the floor of the box and put a hole through it to accept a bolt through 50mm ball. Any thoughts?
   / New Tractor Owner - Pics #6
Congrats, you have a driver too.
   / New Tractor Owner - Pics #8
Richard, one thing that I would recommend you do, is to swap the rear wheels left to right to get a slightly wider rear track. That's assuming it hasn't already been done. Although it's only a small difference it really makes a difference to how stable the whole thing feels.
Bluest,
I will have a look when I am home later, I have a feeling it has been done as its quite deep from the front of the tyre to the central plate.
I will check, feels stable now though. I cant believe how fast it goes in top gear, it really shifts it. Not that it is important, just surprised.
Thanks.
   / New Tractor Owner - Pics #10
I bet yours is quicker than mine, and mine is fast enough! Film it though, it feels a lot faster than it looks.
The easiest way to tell if the wheels have been swapped is the valve stems will be on the inside.
RHINO X1406 LOT NUMBER 64 (A53084)
RHINO X1406 LOT...
2019 FORD F-150 (A52472)
2019 FORD F-150...
LOAD OUT INFORMATION (A53084)
LOAD OUT...
2018 Ford F-550 Flat Bed Truck, VIN # 1FDUF5GTXJEC35552 (A51572)
2018 Ford F-550...
MALONE 3000TP LOT NUMBER 229 (A53084)
MALONE 3000TP LOT...
Manac Walking Floor Trailer (A50322)
Manac Walking...
