kcflhrc
I switched this year to a salt system as well. I truly enjoy the virtual no-maintenance of the system. Once you get the initial chemistry set, just use the pool. Salt levels, PH and CYA need to be adjusted, but basically once at startup, then no more work except an occasional eye on PH.
A warning to anyone using an Intex salt-chlorine generator, most units also add copper to the pool. This is done in a separate "cell" that consists of a couple of copper bars. Copper is a good algecide, but the Intex will keep adding copper. In noprmal conditions the copper ions do not dissipate, and the copper levels will continue to increase. Eventually you will start to get green stains on the liner and blond hair can also develop a green tinge. After researching, the consensus seems to be to get rid of the copper. You can unplug the copper electrodes, but still enough copper is dissolved by the salt-chlorine. I removed the electrodes but left the pins in, held by a couple of nuts. I then filled the area with RTV so the nuts and pins would not corrode. It has been working like a champ in this configuration, and no copper ions.
paul
Ours has those copper bars you are talking about. Do the test strips test for copper? We just got our pool and salt water system up and running this weekend.
