5 gallon pail of oil, need pump recommendations
   / 5 gallon pail of oil, need pump recommendations #1
Happy Gilmore
Southeastern, MA
Ford 5610 Ford 4630 Ford 3930 MFWD w/ 7310 loader Ford 3930 Kubota BX1500 Kubota RTV 900XT Kubota F2680E 72"RD Ford 4610 Kubota KX121-3
I'm looking to get a lever style pump of good quality for dispensing oil from 5 gallon pails. I have a simple plunger style currently which I'm not thrilled with. Any thoughts
   / 5 gallon pail of oil, need pump recommendations #2
   / 5 gallon pail of oil, need pump recommendations #3
Debated whether to post this or not. I don't pump my oil as the arthritis in my shoulders just makes it too much of a pain. I use a 20 lb propane tank with a 3/4" pipe brazed in that goes down to the bottom of the tank. That pipe has a hose with a valve on it that lets me control the flow of the oil. The valve also has a short piece of 1/2" copper pipe on the other end so that I can put the oil in where I want it. The tank also has a 1 1/2" close nipple brazed in that has a 1/4 turn ball valve on it so that I can pour oil into the propane tank. I also installed a pressure gauge (optional), a safety relief (not optional) and an air fill valve for an air chuck. It makes adding oil to a differential under a vehicle very easy. This idea can easily become very dangerous which is why I have a pressure relief valve. 60 lbs air pressure is plenty to move oil around. If you do build something like this take a moment to test the safety of your work. Fill the tank with water and close it all up with a grease zerk and a pressure gauge. Test to at least 100 lbs pressure with a grease gun. Happy oiling!
   / 5 gallon pail of oil, need pump recommendations #5
I think my pump arm would wear out pumping 2 oz of oil per stroke with that. OK if just putting in oil to a rear differential, or a quart or so, but to put in a 5 gallon can full would take a while.
   / 5 gallon pail of oil, need pump recommendations #6
hey know what you mean...try 3x 5 gal for hyd change on the tractor! but....much less mess & chance for contaminates than other more primitive methods i've used. works great for ft axle & changing gear oil in all my vehicles.
Tried out the pump today doing an oil change on the Ford 4630. I have to say it works pretty well. I ended up buying a second one for the Super UDT 2 :thumbsup:
Well I used the second pump today, decided to do the hydrostatic fluid in the BX1500, did the engine oil while I was at it. Since I was having so much fun with the new pumps, I did the engine oil in the 3930 2wd. Need to get another 5 gallon pail of 10W30 and the 5610 will be next. Pumps work great, definately makes the oil changes a lot easier. I'm thinking a third pump will be in the future for the NH hydraulic oil. I've got 3 tractors due for hydraulic oil changes, 40 odd gallons, can't wait :shocked: maybe a drum of hydraulic oil should be in my future
   / 5 gallon pail of oil, need pump recommendations #10
not sure were i picked it up at.... it is a pump, that attaches to a wired/or cordless drill. has garden hose ends on both sides of it. rated for water, oils, diesel, (not regular gas).
also have a couple "hand siphon pumps" toss 5 gallon can of gas up on tractor, stick long hard tube down in can, then stick flex hose down in gas can on tractor, turn a little nob on top and a couple squeezes to start siphon and away it goes. same thing for 5 gallon bucket of oil. i only remember them for use in the old kerosone heaters used as extra heat in the winter, and fueling them up. till a few years back, and now use them for generator, and tractor, and dumping gas into a vehicle if need be.
my issue with the 2 hand lever pumps the others linked to, is they sputter and spit and drip oil during use. and a slight bump and hose falls out. granted always better than dealing with a variety of funnels and have an assortment at that, for what funnel works better without flipping over and spilling.
i might have to check to see if a sprayer pump (for spraying weeds and/or the lawn) can handle oils. more so the pumps with electronic pressure switch for use of a hand wand. for pressure on demand. 12v battery with a battery minder/charger hhmmsss....
2016 WABASH RFALHSA 53FT REEFER TRAILER (A54607)
2016 WABASH...
2021 TAKEUCHI TB240 EXCAVATOR (A52705)
2021 TAKEUCHI...
2011 INTERNATIONAL PROSTAR TANDEM  AXLE MID ROOF SLEEPER (A54313)
2011 INTERNATIONAL...
2007 FORD F750 XL SUPER DUTY SERVICE TRUCK (A51406)
2007 FORD F750 XL...
2003 Chevrolet 3500 (A50120)
2003 Chevrolet...
