Post Photos of your Pole Barn / Stick Barn and Ideas
   / Post Photos of your Pole Barn / Stick Barn and Ideas #1
KenB2920
Almont, Mi
Kubota L5240HSTC
I don't know if this project will start in 10 days or ten years but I would like a barn. Wether it be stick built or pole barn I would like photos of yours and your ideas. Let me know what you would do again or do different if you built it over.
I am roughly looking at a 30x40 size with cement floor. I will be doing some things myself and contracting some things out.
I think I would like to have it heated (by a wood stove) someday, store my tractor and misc other equipment.
Pictures pictures pictures !!!
   / Post Photos of your Pole Barn / Stick Barn and Ideas #2
30 x 40' barn with loft, recently finished.
   / Post Photos of your Pole Barn / Stick Barn and Ideas #3
Built a "Miracle Truss" 30 x 50 myself. With the exception of the slab, I built it alone.
I had to rent a fork lift for a weekend to set up the trusses. Took a couple of months (on weekends)
Make sure you have water and a electric hook up. Still looks like new 15 year later!
Can't think of anything I would do different... good luck with your project.
   / Post Photos of your Pole Barn / Stick Barn and Ideas #4
I agree on water and a electric hook up. I put 12x12 doors on opposite sides to let the prevailing wind blow through when I am working in it. Also have a walk through door to the shed, in case an ice storm freezes the main walk in door, (that happened a lot where we used to live).
Don't need heat here, but should have insulated it.
30 by 40 shop with shed, built by a local guy.
He puts the skylights on the sidewall not on the roof.
   / Post Photos of your Pole Barn / Stick Barn and Ideas #5
30x60...will have three sides closed in..11ft 6in to the bottom of the LVLs...which are 20ft wide..hope I can get the pic to upload...sorry if it doesn't.. BobG in VA
Now that's huge
   / Post Photos of your Pole Barn / Stick Barn and Ideas #9
This was built late last fall but I had to wait until May for the floor and electric to be finished. It was a long winter!!!
   / Post Photos of your Pole Barn / Stick Barn and Ideas #10
24X48 Pole barn with loft
2013 KENWORTH T370 DUMP TRUCK (A51406)
2013 KENWORTH T370...
2016 Ford E-450 LP Handicapped Bus (A55788)
2016 Ford E-450 LP...
Toro GreensMaster 1600 Walk-Behind Reel Mower (A53421)
Toro GreensMaster...
2023 Ford F-150 4x4 Crew Cab Pickup Truck (A55788)
2023 Ford F-150...
