P-trap ?
   / P-trap ? #1
tow653
Gold Member
Gasconade County,Mo
New Holland TC29,Ford Jubilee
We are empty nesters,with a finished basement that has a full and a half bath. How long before the water in the P-traps evaporates,and sewer gas smell occurs? Thanks,just want to know how often I should run water in fixtures that don't get used very often.
   / P-trap ? #2
i would run HOT water thru about once a month...helps keep all the drain lines lower than these clear....easy and fast....
   / P-trap ? #3
I would second the once a month thing. But how long it takes to evap cannot be pinpointed exactly. Smaller 1-1/4" traps hold less water than 1-1/2 ones and will evap quicker. Is your basement damp/wet or do you run a dehumidifier? etc etc.
Is the trap plated brass? or plastic?
IF the plastic kind, you can usually shine a bright flashlight through it from the back side and can see the water level. Kinda like when filling a plastic gas can and its hard to see and you shine a light on it...
   / P-trap ? #4
I'd simply wait until you smell the gas then fill them back up.
   / P-trap ? #6
We have a whirlpool tub that never gets used anymore. 2 or maybe 3 times a year it starts to smell so I put a quart of water down it.
   / P-trap ? #7
If you are never going to use it, fill the P trap with RV antifreeze and it will stay full almost forever.
   / P-trap ? #8
Thats a good idea, maybe Mrs bigtiller can borrow a cup of antifreeze from one of here church-lady friends that camp. We quit camping years ago because our closest neighbor is 1/2 mile away.
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
UNUSED RAYTREE RMBD50 - 50" DRUM MULCHER (A54757)
UNUSED RAYTREE...
2008 CATERPILLAR 12M MOTOR GRADER (A51406)
2008 CATERPILLAR...
Ford 655C 2WD Cab Backhoe (A55218)
Ford 655C 2WD Cab...
2018 Toro Z-Master 6000 Series 74in Zero Turn Commercial Mower (A53421)
2018 Toro Z-Master...
