MIG, TIG and a new helmet...
   / MIG, TIG and a new helmet... #11
Here's one I'd like to try :)
I can think of many times it would haven been great - tight spaces - or no fogging from my breath.
Servore arc shield-513
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=389138"/>
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=389139"/>
I've used round welders goggles with two sets of #5 lenses (5+5=10) to do some welding where I couldn't get a full helmet. If I had to do a lot of welding, I would have needed to cover my face with something.
   / MIG, TIG and a new helmet... #12
Not a link, but here's a pic for those who haven't seen one.
Terry
Those might be OK if the "CAP" would suffice for a hard hat. Most construction jobs now require a welder to wear a hardhat when welding so it is a bit heavy. I'm not too sure what the cap look is supposed to mean though. I always lay my hood down with the back facing the table. I had too many jokers putting water or dirt in it when laid down with the back facing up.
   / MIG, TIG and a new helmet... #13
I didnt know you could double the lens in a goggle to get the benefit of a darker lens. I have a pair of goggles i use for oxy/acet, I might have to give your trick a try the next time I am wadded up in a tight hole trying to make a spark. I might endup looking like a raccoon when its over tho.
Two shade 5 lenses put back to back doesn't equal a shade 10 lens. It might be a little darker but not much.
   / MIG, TIG and a new helmet... #15
Your going to have to explain a little bit. Math says 5+5 should equal 10 so there must be something else at play here.
   / MIG, TIG and a new helmet... #16
Take two shade fives, and compair them to one shade ten. Look at the sun or something. You can also make a shade 13 by pairing an 8 and a 5.
   / MIG, TIG and a new helmet... #18
   / MIG, TIG and a new helmet... #19
So, If I wanted a shade 10 I could use a #5 and a #6 and that would equal a #10. Dont know if i have ever seen a shade 6, have to check the welding supply. Most of my welding is with 1/8 rods so I could probably get by with a shade 9. I saw a chart somewhere that gives recommendations for proper shade for a given rod size and amperage.
Found this on the lincoln site. Welding Helmets and Eye Protection and a similar one is also on the miller site
2011 PETERBILT 367 TRI-DRIVE WITH TAG (A52472)
2011 PETERBILT 367...
1998 CATERPILLAR D250E OFF ROAD DUMP (A51242)
1998 CATERPILLAR...
2000 CATERPILLAR 140H MOTOR GRADER (A51406)
2000 CATERPILLAR...
Chevrolet C8500 Flat Bed with a Moffet Kit (A52128)
Chevrolet C8500...
2020 New Holland 105 Workmaster MFWD Compact Tractor with 632TL Front Loader - Poultry Special (A52128)
2020 New Holland...
2007 GMC Acadia SUV (A50324)
2007 GMC Acadia...
