200 year old oak down.
   / 200 year old oak down. #11
Also wood that "falls" usually falls for some reason. Decay, insect, wind, icing are common causes.
All can greatly affect the quality of milled lumber. It may cost more to get useable lumber from fallen oak than what you would pay at a lumber yard when bought in bulk.
   / 200 year old oak down. #12
For clarification, is the crown on your property and the trunk on the neighbors or has it fallen so some trunk and some crown is on each parcel? Legally it may not matter, I don't know. But if you cut / separate the tree along the property line, the neighbor would need permission from you to recover any wood that would require him coming on to your land.
As stated earlier the crown is good firewood, not good for lumber.
   / 200 year old oak down. #13
"I have had part of an oak fall from the neighbors property onto mine. The oak stradles the property line so I figure what fell on my property is mine."
This is a bit ambiguous, but I think you are saying that the tree was on his property and fell across the bounrdy between the two properties. You want what landed on your property. If that is the case, then I don't think it is your tree at all. The way I see it, if the tree fell from his property onto yours and damaged your fence, shed, house, or car, etc, he would be responsible for the damage. Even if there is no damage, he is responsible to clean up the debris and should clear it with you first before he or any workman go onto your property. With that the case, I think the wood is his if he wants it.
Having said that, I agree with the others who suggested that youu talk to him first, unless you already have a poor relationshiop with your neighbour. For all you know he may not want the wood and may give yo the whole tree. Or maybe he will just want the branches for firewood and will give the trunk to you because it is too large to chunk up and split anyway. WIth all of my neighbours the first thing we would have done was take a walk out to the tree and chew the fat while we consider what to do next.
   / 200 year old oak down. #14
You are neighbors, best to avoid hard feelings.
   / 200 year old oak down. #15
If it was on the line between properties, must sawmills won't want to cut it because it probably has nails in it.
   / 200 year old oak down. #16
Act of god if it falls on your land. Just try and get the neighbor to pay for the damage it caused to your place to see who it belongs to. Anything that falls across the property line is not the responsibility of the person who owns the land that it's growing on, no matter how far across the line it is. The only exception is if there is an obvious problem to the tree or branch that is both documented and your concerns have been made to the neighbor in a way that you can prove. Usually hiring a tree expert.
As for selling it, good luck. Trees are a dime a dozen and it takes too much money to make it into something valuable enough to sell that those who do it have to do it in volume and sell it wholesale to those who can sit on it long enough to make a profit.
Better to just cut it into firewood if you don't want it for your own use
Eddie
   / 200 year old oak down. #17
Maybe in Canada, not in the US. When a tree falls and damages your property in the US unless it is a dead tree and or you have informed the owner of the tree it is a hazard the damage is yours to repair or fix or clean up.
   / 200 year old oak down. #18
It's been my experience when a neighbors tree fell and tore up fence shed and garage,that I and my insurance were responsible for everything on my property.
As far as hiring a sawyer. I would only hire one by the board foot not by the hour. It cuts down on the FO time. Phone calls blade sharpening lunch fuel stops wife needs him etc etc. I paid .50 a bf to have it sawed here. .35 to haul it to him.
I will talk to neighbor. We are have a good relationship. I will have firewood for years.
This is about 1/4 of the tree. Huge base that split into several large tree like projections. The center was rotten.
2000 GMC C7500 CRANE TRUCK (A51406)
2000 GMC C7500...
2025 JOHN DEERE Z325E LOT NUMBER 84 (A53084)
2025 JOHN DEERE...
2011 EAGER BEAVER 35G SL DETACH TRAILER (A52706)
2011 EAGER BEAVER...
2016 Ford F-450 Crew Cab Knapheide Service Truck (A52377)
2016 Ford F-450...
2021 CASE IH 345 LOT NUMBER 12 (A53084)
2021 CASE IH 345...
72'' power rake (A53421)
72'' power rake...
