Anybody know of a rotary blade sharpener?
   / Anybody know of a rotary blade sharpener? #1
MinnesotaEric
Super Member
Nevis, MN
Kioti NX6010
I'm wondering if anybody knows of a rotary blade sharpener?
What I envision is something like a lawn mower blade sharpener, only bigger.
Amazon.com : Oregon 88-023 Professional 1/2 HP Lawnmower Blade Grinder : Lawn Mower Accessories : Patio, Lawn & Garden
   / Anybody know of a rotary blade sharpener? #2
torch
   / Anybody know of a rotary blade sharpener? #4
I don't know what you are looking for specifically, but I have the Oregon 1 1/2 hp 12" wheel blade sharpener. The new blade sharpeners coming out use a ceramic belt either with a 48 or 60" long belt.
   / Anybody know of a rotary blade sharpener? #5
I sharpen blades on a bench grinder with angle attachment. Guess I could use my angle grinder like Newbury does too.
   / Anybody know of a rotary blade sharpener? #6
I prefer to be able to see just how much metal I am removing using my angle grinder and a sanding pad disc. Those abrasive wheels might be ok for computer guided sharpening but I suspect the manual ones would take a lot of time to get the set right unless you just took off a lot of metal.
I timed my self a couple days ago sharpening a rather dull mower blade from my 52" mower using a 120 grit sanding disc and it took 45 seconds for one end so about 2 minutes per blade counting the time to loosen the vise and flip the blade to get a knife edge on it without burning the steel. I doubt you could do it any faster than that with any bench grinder attachment.
   / Anybody know of a rotary blade sharpener? #7
I have 2 sets of blades-- change 'em out, lock in vise, sharpen with 4" angle grinder, too easy. 30 minutes for the whole process.
   / Anybody know of a rotary blade sharpener? #8
Angle grinder here. HF recently had a on line coupon where I picked up a light duty one for $9.99.
   / Anybody know of a rotary blade sharpener? #9
I sharpen blades for my sons three zero turn mowers every week. Use an 4 1/2 inch angle grinder I try to use the same amount of strokes on each side. Can do 9 blades in around 15 minutes. They don't
need to be sharpened to a knife edge.
   / Anybody know of a rotary blade sharpener? #10
I have always used an angle grinder. I believe on a rotary cutter a good edge is all that is needed, not razor sharp.
2022 Wacker Neuson SM100 Mini Skid Steer (A52128)
2022 Wacker Neuson...
80in HD Tooth Bucket with Side Cutters (A52128)
80in HD Tooth...
Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
Bad Boy Outlaw XP...
2017 DITCH WITCH RT30 RIDE-ON TRENCHER (A51242)
2017 DITCH WITCH...
Woods 7200 3 pt Finish Mower (A50514)
Woods 7200 3 pt...
Quick Attach EZ Axe Skid Steer Tree Shear (A52128)
Quick Attach EZ...
