So you want to understand TORQUE?
   / So you want to understand TORQUE? #1
Cat_Driver
Coachella Ca.
2016 Kubota 4060, 2017 Tackeuchi excavator TB260
Embedded media from this media site is no longer available
The BEST PART, the guys gets off the second tractor and hand motions the guy in the first tractor...OK, that's good, you can stop pulling now, while I shut my tractor off. BWAHAHAA like he needed to tell him to STOP PULLING !!!!!
   / So you want to understand TORQUE? #2
TRULY amazing:shocked: I didn't see that one coming. Looks like a design flaw, to me.
   / So you want to understand TORQUE? #3
*slaps on a sign* reason you want a subframe, normally for 3pt backhoes but why not everything else?
*begins to wonder* if i lock up rear wheels, with tractor in 4wd. will the front tires pull the tractor in half?
   / So you want to understand TORQUE? #4
That will buff right out.
   / So you want to understand TORQUE? #5
Quick ... where's the motor rebuild in a can ?
   / So you want to understand TORQUE? #7
Hahahahahaha i wasnt expecting this....
I laughed so hard i almost p%##^* myself!!
   / So you want to understand TORQUE? #8
why, oh, why, in both cases, did they leave the trailer attached to the tractor...seems to me that in both cases you could extract the trailer by detaching and pulling it around/back to get it out using the larger tractor.
But, then, sometimes, people don't think like I do. And hindsight is always helpful.
   / So you want to understand TORQUE? #9
why, oh, why, in both cases, did they leave the trailer attached to the tractor...seems to me that in both cases you could extract the trailer by detaching and pulling it around/back to get it out using the larger tractor. But, then, sometimes, people don't think like I do. And hindsight is always helpful.
did you get a laugh or was it just me?
   / So you want to understand TORQUE? #10
Naahhhh... they were mobile mechanics needing to split that tractor..... just didn't have the right size socket for the housing bolts !
:rolleyes:
If you can see mostly air under a tractor, around these parts that ain't Stuck ! Not even close.
I think next time they'll unhook and then chain up both tractors directly to the stuck wagon.... it's not called a drawbar because they ran out of other names.....
Rgds, D.
2007 Ford E-450 Super Duty 16ft Portable Office Truck (A54814)
2007 Ford E-450...
2014 Ford F-150 Ext. Cab 4x4 Pickup Truck (A53422)
2014 Ford F-150...
2006 Utility Trailer Trailer, VIN # 1UYVS13256P972701 (A53422)
2006 Utility...
Galvanized Livestock Gate (A55218)
Galvanized...
2018 KENWORTH T800 DAYCAB (INOPERABLE) (A53843)
2018 KENWORTH T800...
