2008 Jinma 284 Maintenance Info
   / 2008 Jinma 284 Maintenance Info #1
MadMopar
Member
Bennett, CO
2008 Jinma 284
Hi Folks.
Does anyone have accurate info on the filter types (NAPA, WIX, etc.), fluids (weights, etc.) and plugs that a 2008 Jinma 284 tractor with a front loader uses/requires.
I getting ready to do a full maintenance run on mine for the first time (bought a year ago) and I have several conflicting sources of info.
Any help would be appreciated.
Thanks
   / 2008 Jinma 284 Maintenance Info #2
Here is a matrix that I have used for my 286
erj, thanks for the chart.
Does this work with the 284 also.
   / 2008 Jinma 284 Maintenance Info #4
sorry, hit the wrong key - meant 284
Has anyone got a list of the correct fluids to use in this machine.
I know it uses the following:
10W-40 Diesel Oil
Standard Anti-Freeze in a 50/50 mix
Lithium or Molybdenum Grease
I need to know the following:
Hydraulic (2.5 Gallons) - Good quality 'lightweight' fluid?
Transmission/Transfer Case - Standard or Tractor Hydraulic Fluid? (I have sheet that says 80-90W Oil) (Don't know capacity)
Front Axle - Same as Tranny? (I have a sheet that says 80-90W Oil) (Don't know capacity)
Also, can anyone tell me if I have an "Injection Pump" and where it is located. My understanding is that it uses ISO 100 Compressor Oil. If it's what I think it is, it sets below and behind the alternator.
Erj sent me a filter list that looks about right. I'm not sure of the air filter yet. I'll know when I get it in on Thursday.
Once I can get a complete list of filters and fluids that are correct, I'll be more than happy to post it here for anyone else.
This my first time doing this or any tractor, so I am a little uncertain on some of the things. Everything pretty much looks straight forward.
Thanks for any help.
   / 2008 Jinma 284 Maintenance Info #7
Here is a picture of injector - I use the same oil that I do in the engine.
Am I understanding that this is a fuel injector?
   / 2008 Jinma 284 Maintenance Info #9
10W-40 Diesel Oil
Just to throw a monkey wrench into the works :)
15w-40 oil
diesel AF
Regular chassis grease Ep-2
is what I use in mine
AW-32 in mine, might have to go a bit lighter if it's really cold or change it depending on the season. Cold weather I just let mine run a bit to warm it up and it's good to go. Can't swear to the quantity as it's been awhile since I changed mine but i thought it was closer to 5 gallons I could be wrong tho.
80-90 gear oil, again I remember buying a 5 gallon pail but it might have been a bit shy by the time I did the front and read diff
80-90 gear oil, make sure you get all three drain plugs and make sure the vents are clear. The oil will flow across from one side to the other, make sure you allow enough time to be sure you have the correct amount.
As ERJ posted, that's the pump. Let the engine warm up a bit and drain it from both drains and fill it from the vent. Leave the rubber cap off the over flow till you see the oil coming out, wait until it stops and you're good to go, be sure to replace the cap. Engine oil, 15W-40.
I was just told a couple of days ago that Belarus uses the same injection pump and the common weak point on them was people not changing the injector oil as it`ll get contaminated with leakby fuel and ruin the pump. For the sake of a few ML of oil I do mine between oil changes even tho I don`t smell fuel......Mike
diesel AF
Didn't know there was a difference, so I'll look for it.
Already have a grease gun with lithium, so I'll go ahead and use it.
I'm not sure what this is. Is this what they talk about as lightweight in the manuals?
Looks like I'll just have to get a few gallons. Is there is certain grade or class for the 80W-90 oil?
Thanks for the tip on the drains and fill.
Thanks for this info. I hadn't even seen anything about this pump until I caught a hint of it on some chart or something somewhere. Sometimes ya just get overloaded with too much info that isn't needed.
Don't take that wrong, you and erj have been a great help and I think I've got a good lock on everything now. Now it's just to get all the parts and the time to do it all in one fell swoop.
Thanks again for your help.
2015 KUBOTA 1140CRX RTV (A51406)
2015 KUBOTA...
2011 Chevrolet Uplander Van (A51694)
2011 Chevrolet...
FECON SKID STEER QUICK ATTACH HYD MULCHING HEAD (A51406)
FECON SKID STEER...
2017 Nissan Altima Sedan (A51694)
2017 Nissan Altima...
100 GAL FUEL TANK AND TOOLBOX COMBO (A53843)
100 GAL FUEL TANK...
Peterbilt (A51692)
Peterbilt (A51692)
